NANO EMMC SPI signal seen on the scope is abnormal
After modify these files ,the nano can receive data by jump MOSI and MISO.
./hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi
./hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
./kernel/kernel-4.9/drivers/spi/spi-tegra114.c
./kernel/kernel-4.9/drivers/gpio/gpio-tegra.c
nvidia@nvidia:~$ cat /etc/nv_tegra_release | head -n 1
# R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t210ref, EABI: aarch64, DATE: Mon Jul 26 19:20:30 UTC 2021
Howere, the signal seen on the scope is abnormal
BLUE: MOSI
YELLOW:SCK
How to make it work normally?
Any correct signal to compare?
correct signal like this, it is generated by raspberrypi
any help?
@qgq1991
Could you share your modification here to review.
gpio-tegra.c (21.8 KB)
spi-tegra114.c (59.2 KB)
tegra210-porg-gpio-p3448-0002-b00.dtsi (2.3 KB)
tegra210-porg-p3448-common.dtsi (21.8 KB)
diff -u ./kernel/kernel-4.9/drivers/spi/spi-tegra114.c.bak ./kernel/kernel-4.9/drivers/spi/spi-tegra114.c
$ diff -u ./hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi.bak ./hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi
--- ./hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi.bak	2021-11-05 14:32:19.880802429 +0800
+++ ./hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-porg-p3448-common.dtsi	2021-11-05 14:35:37.000000000 +0800
@@ -196,7 +196,8 @@
 	hdr40_spi1: spi@7000d400 { /* SPI 1 to 40 pin header */
 		status = "okay";
 		spi@0 {
-			compatible = "tegra-spidev";
+            status = "okay";
+			compatible = "spidev";
 			reg = <0x0>;
 			spi-max-frequency = <33000000>;
 			controller-data {
@@ -205,7 +206,8 @@
 		spi@1 {
+            status = "okay";
 			reg = <0x1>;
 			controller-data {
$ diff -u ./hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi.bak ./hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi
--- ./hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi.bak	2021-11-29 18:26:33.065072832 +0800
+++ ./hardware/nvidia/platform/t210/porg/kernel-dts/porg-platforms/tegra210-porg-gpio-p3448-0002-b00.dtsi	2021-11-05 14:26:21.000000000 +0800
@@ -1,81 +1,90 @@
-/*This dtsi file was generated by T210_P3448_SKU2_pinmux.xlsm Revision: 17 */
- * Copyright (c) 2018-2019, NVIDIA CORPORATION.  All rights reserved.
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation; either version 2 of the License, or
- * (at your option) any later version.
- * This program is distributed in the hope that it will be useful, but WITHOUT
- * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
- * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
- * more details.
- * You should have received a copy of the GNU General Public License along
- * with this program; if not, write to the Free Software Foundation, Inc.,
- * 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301, USA.
-#include <dt-bindings/gpio/tegra-gpio.h>
-	gpio: gpio@6000d000 {
-		gpio-init-names = "default";
-		gpio-init-0 = <&gpio_default>;
-		gpio_default: default {
-			gpio-input = <
-				TEGRA_GPIO(BB, 0)
-				TEGRA_GPIO(B, 4)
-				TEGRA_GPIO(B, 5)
-				TEGRA_GPIO(B, 6)
-				TEGRA_GPIO(B, 7)
-				TEGRA_GPIO(DD, 0)
-				TEGRA_GPIO(E, 6)
-				TEGRA_GPIO(S, 5)
-				TEGRA_GPIO(A, 5)
-				TEGRA_GPIO(X, 4)
-				TEGRA_GPIO(X, 5)
-				TEGRA_GPIO(X, 6)
-				TEGRA_GPIO(Y, 1)
-				TEGRA_GPIO(Y, 2)
-				TEGRA_GPIO(V, 0)
-				TEGRA_GPIO(V, 1)
-				TEGRA_GPIO(Z, 0)
-				TEGRA_GPIO(Z, 2)
-				TEGRA_GPIO(J, 5)
-				TEGRA_GPIO(J, 6)
-				TEGRA_GPIO(J, 4)
-				TEGRA_GPIO(J, 7)
-				TEGRA_GPIO(G, 2)
-				TEGRA_GPIO(G, 3)
-				TEGRA_GPIO(C, 0)
-				TEGRA_GPIO(C, 1)
-				TEGRA_GPIO(C, 2)
-				TEGRA_GPIO(C, 3)
-				TEGRA_GPIO(C, 4)
-				TEGRA_GPIO(H, 2)
-				TEGRA_GPIO(H, 5)
-				TEGRA_GPIO(H, 6)
-				TEGRA_GPIO(CC, 4)
-			gpio-output-low = <
-				TEGRA_GPIO(S, 7)
-				TEGRA_GPIO(T, 0)
-				TEGRA_GPIO(H, 0)
-				TEGRA_GPIO(H, 3)
-				TEGRA_GPIO(H, 4)
-				TEGRA_GPIO(H, 7)
-				TEGRA_GPIO(I, 0)
-				TEGRA_GPIO(I, 2)
-			gpio-output-high = <
-				TEGRA_GPIO(A, 6)
-				TEGRA_GPIO(X, 3)
-				TEGRA_GPIO(I, 1)
-				TEGRA_GPIO(CC, 7)
+/*This dtsi file was generated by T210_P3448_SKU2_pinmux.xlsm Revision: 17 */
+ * Copyright (c) 2018-2019, NVIDIA CORPORATION.  All rights reserved.
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; either version 2 of the License, or
+ * (at your option) any later version.
+ * This program is distributed in the hope that it will be useful, but WITHOUT
+ * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
+ * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
+ * more details.
+ * You should have received a copy of the GNU General Public License along
+ * with this program; if not, write to the Free Software Foundation, Inc.,
+ * 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301, USA.
+#include <dt-bindings/gpio/tegra-gpio.h>
+	gpio: gpio@6000d000 {
+		gpio-init-names = "default";
+		gpio-init-0 = <&gpio_default>;
+		gpio_default: default {
+        	gpio-hog;
+            function;
+            gpios = <
+                TEGRA_GPIO(C, 0) 0
+                TEGRA_GPIO(C, 1) 0
+                TEGRA_GPIO(C, 2) 0
+                TEGRA_GPIO(C, 3) 0
+                TEGRA_GPIO(C, 4) 0
+			gpio-input = <
+				TEGRA_GPIO(BB, 0)
+				TEGRA_GPIO(B, 4)
+				TEGRA_GPIO(B, 5)
+				TEGRA_GPIO(B, 6)
+				TEGRA_GPIO(B, 7)
+				TEGRA_GPIO(DD, 0)
+				TEGRA_GPIO(E, 6)
+				TEGRA_GPIO(S, 5)
+				TEGRA_GPIO(A, 5)
+				TEGRA_GPIO(X, 4)
+				TEGRA_GPIO(X, 5)
+				TEGRA_GPIO(X, 6)
+				TEGRA_GPIO(Y, 1)
+				TEGRA_GPIO(Y, 2)
+				TEGRA_GPIO(V, 0)
+				TEGRA_GPIO(V, 1)
+				TEGRA_GPIO(Z, 0)
+				TEGRA_GPIO(Z, 2)
+				TEGRA_GPIO(J, 5)
+				TEGRA_GPIO(J, 6)
+				TEGRA_GPIO(J, 4)
+				TEGRA_GPIO(J, 7)
+				TEGRA_GPIO(G, 2)
+				TEGRA_GPIO(G, 3)
+				/*TEGRA_GPIO(C, 0)*/
+				/*TEGRA_GPIO(C, 1)*/
+				/*TEGRA_GPIO(C, 2)*/
+				/*TEGRA_GPIO(C, 3)*/
+				/*TEGRA_GPIO(C, 4)*/
+				TEGRA_GPIO(H, 2)
+				TEGRA_GPIO(H, 5)
+				TEGRA_GPIO(H, 6)
+				TEGRA_GPIO(CC, 4)
+			gpio-output-low = <
+				TEGRA_GPIO(S, 7)
+				TEGRA_GPIO(T, 0)
+				TEGRA_GPIO(H, 0)
+				TEGRA_GPIO(H, 3)
+				TEGRA_GPIO(H, 4)
+				TEGRA_GPIO(H, 7)
+				TEGRA_GPIO(I, 0)
+				TEGRA_GPIO(I, 2)
+			gpio-output-high = <
+				TEGRA_GPIO(A, 6)
+				TEGRA_GPIO(X, 3)
+				TEGRA_GPIO(I, 1)
+				TEGRA_GPIO(CC, 7)
keygo@keygo-txflash:~/Linux_for_Tegra/source/public$ diff -u ./kernel/kernel-4.9/drivers/gpio/gpio-tegra.c.bak ./kernel/kernel-4.9/drivers/gpio/gpio-tegra.c
--- ./kernel/kernel-4.9/drivers/gpio/gpio-tegra.c.bak	2021-11-05 14:27:15.093797696 +0800
+++ ./kernel/kernel-4.9/drivers/gpio/gpio-tegra.c	2021-11-05 15:53:12.000000000 +0800
@@ -217,6 +217,11 @@
 	tegra_gpio_mask_write(tgi, GPIO_MSK_CNF(tgi, gpio), gpio, 1);
+static void tegra_gpio_disable(struct tegra_gpio_info *tgi, int gpio)
+       tegra_gpio_mask_write(tgi, GPIO_MSK_CNF(tgi, gpio), gpio, 0);
 static int tegra_gpio_request(struct gpio_chip *chip, unsigned offset)
 	tegra_gpio_save_gpio_state(offset);
@@ -225,8 +230,12 @@
 static void tegra_gpio_free(struct gpio_chip *chip, unsigned offset)
+    struct tegra_gpio_info *tgi = gpiochip_get_data(chip);
 	pinctrl_free_gpio(chip->base + offset);
 	tegra_gpio_restore_gpio_state(offset);
+    tegra_gpio_disable(tgi, offset);
 static void tegra_gpio_set(struct gpio_chip *chip, unsigned offset, int value)
@@ -796,7 +805,10 @@
 	tegra_gpio_debuginit(tgi);
 	register_syscore_ops(&tegra_gpio_syscore_ops);
+    // free spi0 pins
+    for (gpio = 16; gpio <= 20; gpio++) {
+        tegra_gpio_free(&tgi->gc, gpio);
 	return 0;
--- ./kernel/kernel-4.9/drivers/spi/spi-tegra114.c.bak	2021-11-29 18:33:44.805837392 +0800
+++ ./kernel/kernel-4.9/drivers/spi/spi-tegra114.c	2021-11-08 12:26:07.000000000 +0800
@@ -1490,10 +1490,11 @@
 		msg->actual_length += xfer->len;
 complete_xfer:
-		if (prefer_last_used_cs)
+		// if (prefer_last_used_cs)
 			cmd1 = tspi->command1_reg;
-		else
-			cmd1 = tspi->def_command1_reg;
+		// else
+			// cmd1 = tspi->def_command1_reg;
 		if (ret < 0 || skip) {
 			if (cstate && cstate->cs_gpio_valid)
 				gpio_set_value(spi->cs_gpio, gval);
@ShaneCCC Thanks
