I followed the procedure:
Raspberry Pi HQ camera IMX477 Linux driver for Jetson
1/ flash jetson nano developer kit with sdkmanager
2/ Install the debian packages in your board:
sudo apt-get install --reinstall ./nvidia-l4t-kernel_4.9.140-tegra-32.4.3-20200625213809_arm64.deb
sudo apt-get install --reinstall ./nvidia-l4t-kernel-dtbs_4.9.140-tegra-32.4.3-20200625213809_arm64.deb
echo “FDT /boot/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb” | sudo tee -a /boot/extlinux/extlinux.conf
3/ reboot
4/ Let’s try …
jd@jd-jetson:~$ SENSOR_ID=0
jd@jd-jetson:~$ FRAMERATE=30
jd@jd-jetson:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=$SENSOR_ID ! “video/x-raw(memory:NVMM),width=1920,height=1080,framerate=$FRAMERATE/1” ! nvvidconv ! nvoverlaysink
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:557 No cameras available
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.212757966
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
jd@jd-jetson:~$
5/ Where did I goofed ?
- I tried both MIPI slot
- the point 8 resistor was off on the Raspberrycam board
- and Arducam IMX219 works fine when I suppress :
from extlinux.conf file
6/ Thanks for your help
