I recently got a Jetson Nano Developer Kit (P3450-0000) I have tried multiple times to get this Nano going. I’ve tried SD image, even a new SD card, but would not boot up. I’ve tried headless and with monitor/keybaord setups. I’ve tried the SDK multiple times and now on a fresh 18.04 install and it is getting stuck at 99%.
Moved on to the L4T installer script, but keeps stalling. I’ve tried both jetson-nano-devkit and jetson-nano-qspi-sd for ${BOARD}, but both stall out for over an hour.
Any ideas? Don’t want to give up on Nano yet, next move would be a replacement.
sudo ./flash.sh jetson-nano-devkit mmcblk0p1
L4T BSP Information:
R32 , REVISION: 6.1
Target Board Information:
Name: jetson-nano-devkit, Board Family: t210ref, SoC: Tegra 210,
OpMode: production, Boot Authentication: ,
Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet “/home/newton/Downloads/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0016 ] Generating RCM messages
[ 0.0038 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/newton/Downloads/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0045 ] RCM 0 is saved as rcm_0.rcm
[ 0.0051 ] RCM 1 is saved as rcm_1.rcm
[ 0.0051 ] List of rcm files are saved in rcm_list.xml
[ 0.0051 ]
[ 0.0051 ] Signing RCM messages
[ 0.0070 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0076 ] Assuming zero filled SBK key
[ 0.0121 ]
[ 0.0121 ] Copying signature to RCM mesages
[ 0.0143 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0159 ]
[ 0.0160 ] Boot Rom communication
[ 0.0183 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0193 ] RCM version 0X210001
[ 0.0615 ] Boot Rom communication completed
[ 1.0692 ]
[ 1.0693 ] dump EEPROM info
[ 1.0724 ] tegrarcm --oem platformdetails eeprom /home/newton/Downloads/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0739 ] Applet version 00.01.0000
[ 1.0767 ] Saved platform info in /home/newton/Downloads/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1536 ]
[ 1.1567 ] tegrarcm --reboot recovery
[ 1.1581 ] Applet version 00.01.0000
[ 1.1608 ]
Board ID(3448) version(402)
copying bctfile(/home/newton/Downloads/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)… done.
copying bootloader(/home/newton/Downloads/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying initrd(/home/newton/Downloads/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
Making Boot image… done.
Existing sosfile(/home/newton/Downloads/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/newton/Downloads/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
copying cpu_bootloader(/home/newton/Downloads/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying bpffile(/home/newton/Downloads/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
copying wb0boot(/home/newton/Downloads/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/home/newton/Downloads/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/newton/Downloads/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/newton/Downloads/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
Copying nv_boot_control.conf to rootfs
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating kernel_tegra210-p3448-0000-p3449-0000-b00.dtb to rootfs… done.
Making system.img…
populating rootfs from /home/newton/Downloads/Linux_for_Tegra/rootfs … populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Existing tbcfile(/home/newton/Downloads/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/newton/Downloads/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
copying cfgfile(/home/newton/Downloads/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_max-spi_sd_p3448.xml) to flash.xml… done.
copying flasher(/home/newton/Downloads/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
Existing flashapp(/home/newton/Downloads/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --odmdata 0xa4000 --bldtb kernel_tegra210-p3448-0000-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x21 --bins “EBT cboot.bin; DTB tegra210-p3448-0000-p3449-0000-b00.dtb”
saving flash command in /home/newton/Downloads/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/newton/Downloads/Linux_for_Tegra/bootloader/flash_win.bat
assign_value: crc-flash.xml.bin 1 65520 1
printf ‘\x1’ | dd of=crc-flash.xml.bin bs=1 seek=65520 count=1 conv=notrunc
1+0 records in
1+0 records out
1 byte copied, 4.3148e-05 s, 23.2 kB/s
assign_value: crc-flash.xml.bin 0 65521 1
printf ‘\x0’ | dd of=crc-flash.xml.bin bs=1 seek=65521 count=1 conv=notrunc
1+0 records in
1+0 records out
1 byte copied, 2.5609e-05 s, 39.0 kB/s
assign_string: crc-flash.xml.bin PTHD 65528 4
echo PTHD | dd of=crc-flash.xml.bin bs=1 seek=65528 count=4 conv=notrunc
4+0 records in
4+0 records out
4 bytes copied, 4.0351e-05 s, 99.1 kB/s
*** Flashing target device started. ***
version 1.0.0
[ 0.0013 ] tegrasign --getmode mode.txt --key None
[ 0.0020 ] Assuming zero filled SBK key
[ 0.0039 ]
[ 0.0040 ] Generating RCM messages
[ 0.0053 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0059 ] RCM 0 is saved as rcm_0.rcm
[ 0.0078 ] RCM 1 is saved as rcm_1.rcm
[ 0.0080 ] List of rcm files are saved in rcm_list.xml
[ 0.0080 ]
[ 0.0080 ] Signing RCM messages
[ 0.0099 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0105 ] Assuming zero filled SBK key
[ 0.0154 ]
[ 0.0154 ] Copying signature to RCM mesages
[ 0.0179 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0190 ]
[ 0.0191 ] Parsing partition layout
[ 0.0211 ] tegraparser --pt flash.xml.tmp
[ 0.0224 ]
[ 0.0226 ] Using default ramcode: 0
[ 0.0226 ] Disable BPMP dtb trim, using default dtb
[ 0.0226 ]
[ 0.0226 ] Creating list of images to be signed
[ 0.0246 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.0293 ]
[ 0.0293 ] Generating signatures
[ 0.0315 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0325 ] Assuming zero filled SBK key
[ 0.0817 ]
[ 0.0818 ] Generating br-bct
[ 0.0835 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.0898 ]
[ 0.0899 ] Updating boot device parameters
[ 0.0921 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.0930 ] Warning: No sdram params
[ 0.0934 ]
[ 0.0934 ] Updating bl info
[ 0.0954 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.0965 ]
[ 0.0965 ] Updating secondary storage information into bct
[ 0.0985 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 0.0993 ]
[ 0.0993 ] Updating Odmdata
[ 0.1012 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 0.1018 ] Warning: No sdram params
[ 0.1019 ]
[ 0.1020 ] Get Signed section of bct
[ 0.1040 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.1050 ]
[ 0.1051 ] Signing BCT
[ 0.1090 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.1097 ] Assuming zero filled SBK key
[ 0.1101 ]
[ 0.1101 ] Updating BCT with signature
[ 0.1121 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.1129 ]
[ 0.1129 ] Copying signatures
[ 0.1149 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.1184 ]
[ 0.1185 ] Updating BFS information on BCT
[ 0.1207 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.1220 ]
[ 0.1220 ] Boot Rom communication
[ 0.1243 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.1253 ] BR_CID: 0x321010016430b74218000000180484c0
[ 0.1261 ] RCM version 0X210001
[ 0.1401 ] Boot Rom communication completed
[ 1.1480 ]
[ 1.1481 ] Sending BCTs
[ 1.1517 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 1.1537 ] Applet version 00.01.0000
[ 1.1571 ] Sending bct
[ 1.1573 ] […] 100%
[ 1.3812 ]
[ 1.3857 ] tegrahost --chip 0x21 --align cboot.bin
[ 1.3878 ]
[ 1.3915 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 1.3975 ]
[ 1.4030 ] tegrasign --key None --list cboot.bin_list.xml
[ 1.4053 ] Assuming zero filled SBK key
[ 1.4322 ]
[ 1.4349 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 1.4366 ]
[ 1.4394 ] tegrahost --chip 0x21 --align tegra210-p3448-0000-p3449-0000-b00.dtb
[ 1.4402 ]
[ 1.4423 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0000-p3449-0000-b00.dtb tegra210-p3448-0000-p3449-0000-b00.dtb_blheader
[ 1.4442 ]
[ 1.4469 ] tegrasign --key None --list tegra210-p3448-0000-p3449-0000-b00.dtb_list.xml
[ 1.4479 ] Assuming zero filled SBK key
[ 1.4556 ]
[ 1.4580 ] tegrahost --updatesigheader tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0000-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 1.4593 ]
[ 1.4597 ] Sending bootloader and pre-requisite binaries
[ 1.4617 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-b00.dtb.encrypt 0
[ 1.4625 ] Applet version 00.01.0000
[ 1.4775 ] Sending ebt
[ 1.4776 ] […] 100%
[ 1.5830 ] Sending rp1
[ 1.5875 ] […] 100%
[ 1.6430 ]
[ 1.6466 ] tegrarcm --boot recovery
[ 1.6484 ] Applet version 00.01.0000
[ 1.6677 ]
[ 1.6678 ] Retrieving storage infomation
[ 1.6710 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 1.6728 ] Applet is not running on device. Continue with Bootloader
[ 849.1734 ]
[ 849.1780 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 849.1798 ] Cboot version 00.01.0000
[ 849.1836 ] Saved platform info in storage_info.bin
