NanoDB Crushing on startup
I followed the installation tutorial of NanoDB in this link: NanoDB - NVIDIA Jetson AI Lab
And when trying to start the service after setup with the provided command it crushes with the following error:
-- loading CLIP ViT-L/14@336px
CLIP(
  (visual): VisionTransformer(
    (conv1): Conv2d(3, 1024, kernel_size=(14, 14), stride=(14, 14), bias=False)
    (ln_pre): LayerNorm((1024,), eps=1e-05, elementwise_affine=True)
    (transformer): Transformer(
      (resblocks): Sequential(
        (0): ResidualAttentionBlock(
          (attn): MultiheadAttention(
            (out_proj): NonDynamicallyQuantizableLinear(in_features=1024, out_features=1024, bias=True)
          (ln_1): LayerNorm((1024,), eps=1e-05, elementwise_affine=True)
          (mlp): Sequential(
            (c_fc): Linear(in_features=1024, out_features=4096, bias=True)
            (gelu): QuickGELU()
            (c_proj): Linear(in_features=4096, out_features=1024, bias=True)
          (ln_2): LayerNorm((1024,), eps=1e-05, elementwise_affine=True)
        (1): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (2): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (3): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (4): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (5): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (6): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (7): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (8): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (9): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (10): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (11): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (12): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (13): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (14): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (15): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (16): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (17): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (18): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (19): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (20): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (21): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (22): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
        (23): ResidualAttentionBlock(
          (mlp): Sequential(
            (gelu): QuickGELU()
    (ln_post): LayerNorm((1024,), eps=1e-05, elementwise_affine=True)
          (out_proj): NonDynamicallyQuantizableLinear(in_features=768, out_features=768, bias=True)
        (ln_1): LayerNorm((768,), eps=1e-05, elementwise_affine=True)
        (mlp): Sequential(
          (c_fc): Linear(in_features=768, out_features=3072, bias=True)
          (gelu): QuickGELU()
          (c_proj): Linear(in_features=3072, out_features=768, bias=True)
        (ln_2): LayerNorm((768,), eps=1e-05, elementwise_affine=True)
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
        (mlp): Sequential(
          (gelu): QuickGELU()
  (token_embedding): Embedding(49408, 768)
  (ln_final): LayerNorm((768,), eps=1e-05, elementwise_affine=True)
-- ViT-L/14@336px warmup
│ name         │ ViT-L/14@336px       │
│ dtype        │ torch.float16        │
│ crop         │ False                │
│ input_shape  │ (336, 336)           │
│ output_shape │ torch.Size([1, 768]) │
-- creating CUDA stream <CUstream 0xaaab4c6e70b0>
-- creating CUDA vector index (699050,768) dtype=float16 metric=cosine
-- allocating 1073740800 bytes (1024.00 MB) with cudaMallocManaged()
-- allocating 1536 bytes (0.00 MB) with cudaMallocManaged()
-- allocating 5592400 bytes (5.33 MB) with cudaMallocManaged()
-- allocating 2796200 bytes (2.67 MB) with cudaMallocManaged()
  File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
    exec(code, run_globals)
  File "/opt/nanodb/nanodb/__main__.py", line 66, in <module>
    server = Server(db, host=args.host, port=args.port)
  File "/opt/nanodb/nanodb/server.py", line 35, in __init__
    self.create_ui()
  File "/opt/nanodb/nanodb/server.py", line 85, in create_ui
    self.gallery_images = self.get_random_images(self.gallery_size)
  File "/opt/nanodb/nanodb/server.py", line 43, in get_random_images
    indexes = np.random.randint(0, len(self.db)-1, n)
  File "numpy/random/mtrand.pyx", line 781, in numpy.random.mtrand.RandomState.randint
  File "numpy/random/_bounded_integers.pyx", line 1334, in numpy.random._bounded_integers._rand_int64
ValueError: high <= 0
Hi @0910mogo, what’s the command that you ran, and had you already populated the NanoDB with images (or downloaded my example NanoDB)?
I think this might be a bug where you try to start the webserver before any images are actually loaded into the NanoDB…
Hey , @dusty_nv I am a big fan!
I tried running the run command: jetson-containers run $(autotag nanodb) \ python3 -m nanodb \ --path /data/nanodb/coco/2017 \ --server --port=7860
After downloading the indexescd jetson-containers/data wget https://nvidia.box.com/shared/static/icw8qhgioyj4qsk832r4nj2p9olsxoci.gz -O nanodb_coco_2017.tar.gz tar -xzvf nanodb_coco_2017.tar.gz
I will try to manually index the data and lets see in a couple of hours if this solves the issue
Ok gotcha - if post more of your log above, I should be able to see if it is actually finding the pre-indexed NanoDB that you downloaded, but my guess is that it wasn’t. I would recommend trying to index a subset or stopping it (it should automatically save itself every 1000 images) just to check that it’s working for you.
