NanoDB fails to start
I followed this tutorial:NanoDB - NVIDIA Jetson AI Lab to set up NanoDB.
command I’m trying is
./run.sh $(./autotag nanodb) python3 -m nanodb --path /srv/nanodb/coco/2017 --server --port=7860
but NanoDB fails to start with the error
NanoDb scan also fails
Please, mind where the dataset is unpacked. It should be rather inside of git repo itself, under jetson_container/data then at root of the filesystem. Then it getting mounted to docker correctly.
Thank you @vgrechin, glad you got it loaded - you can do that or mount your own folder with the dataset into the container when you start it using Docker’s --volume flag.
