My guess is that nanosleep may have an undocumented upper bound on the argument.
This seems to work for me:
$ cat t2004.cu
#include <stdio.h>
#define RUNTIME_API_CALL(apiFuncCall) \
do { \
cudaError_t _status = apiFuncCall; \
if (_status != cudaSuccess) { \
fprintf(stderr, "%s:%d: error: function %s failed with error %s.\n", \
__FILE__, __LINE__, #apiFuncCall, cudaGetErrorString(_status)); \
exit(-1); \
} while (0)
__global__ void kernel() {
#if __CUDA_ARCH__ >= 700
for (int i = 0; i < 1000; i++)
__nanosleep(1000000U); // ls
#else
printf(">>> __CUDA_ARCH__ !\n");
#endif
int main() {
cudaEvent_t start, stop;
RUNTIME_API_CALL(cudaEventCreate(&start));
RUNTIME_API_CALL(cudaEventCreate(&stop));
RUNTIME_API_CALL(cudaEventRecord(start));
kernel<<<1, 1>>>();
RUNTIME_API_CALL(cudaEventRecord(stop));
RUNTIME_API_CALL(cudaEventSynchronize(stop));
float duration;
RUNTIME_API_CALL(cudaEventElapsedTime(&duration, start, stop));
printf("Elapsed time: %fms\n", duration);
return 0;
$ nvcc -arch=sm_70 -o t2004 t2004.cu
$ ./t2004
Elapsed time: 1048.487671ms
In the above example, if I pass arguments that are 1000000 or less to nanosleep, I get approximately expected timing. If I pass arguments that are 10000000 or greater, I don’t. So I guess there is a threshold of some sort between 1000000 and 10000000.
You might wish to file a bug. It’s possible this is a documentation issue, or there may be some other issue I am not aware of.
It seems probable that the only actual guarantee is that the actual sleep duration will be in the range [0, 2*t] where t is the argument. Given that, I couldn’t categorically state that any guarantees are violated, but the function behavior is curious around that threshold and I can’t explain it.
