Navigation: How can I access the plane controls (squares) in certain angles?
As a max-user, your last picked axis is remembered. So if I pick XY, I can still access it later.
In Omniverse Create, I need to access the square.
But sometimes it disappears - is there anything I can do about it?
If you jump into perspective mode and fly to a different viewing angle, the axis gizmo planes should appear. Is this what you’re after?
