We found a nb-IOT hat for raspberry pi , is that compatible with jetson ?
Hi karthikeyan,
I can’t answer that, may other developers share their thoughts if it can work on Nano.
You haven’t mentioned which nb-IOT hat your wanting to use?
@kayccc and @jas-mx thanks for reply .
i prefer NB-IoT/eMTC/EDGE/GPRS/GNSS HAT for Raspberry Pi, Based on SIM7000E to use.
For that hat to work with J40 connector on the nano you would need to ‘re-mux’ some of the pins ie PWR & DTR if want to use them. Otherwise if you just want to use the UART pins + 3.3v power then I can’t see why it won’t work. The waveshare wiki provides good documentation on the pin used when connecting to RPI.
@jas-mx thanks for reply ; i will try and let you know
