I tested cublas on H100:
#include <iostream>
#include <cuda_runtime.h>
#include <cublas_v2.h>
#include <cuda_fp16.h>
#include <chrono>
#define CHECK_CUDA(call) \
if((call) != cudaSuccess) { \
std::cerr << "CUDA error at " << __FILE__ << ":" << __LINE__ << ": " << cudaGetErrorString(call) << std::endl; \
exit(1); \
#define CHECK_CUBLAS(call) \
if((call) != CUBLAS_STATUS_SUCCESS) { \
std::cerr << "cuBLAS error at " << __FILE__ << ":" << __LINE__ << std::endl; \
exit(1); \
void initialize_matrix(half *matrix, int rows, int cols, half value) {
half *host_matrix = new half[rows * cols];
for (int i = 0; i < rows * cols; ++i) {
host_matrix[i] = value;
CHECK_CUDA(cudaMemcpy(matrix, host_matrix, rows * cols * sizeof(half), cudaMemcpyHostToDevice));
delete[] host_matrix;
void print_first_element(half *matrix) {
half host_value;
CHECK_CUDA(cudaMemcpy(&host_value, matrix, sizeof(half), cudaMemcpyDeviceToHost));
std::cout << "First element: " << __half2float(host_value) << std::endl;
void handle_cublas_status(cublasStatus_t status) {
if (status != CUBLAS_STATUS_SUCCESS) {
std::cerr << "cublasGemmEx failed with error code: " << status << std::endl;
switch(status) {
case CUBLAS_STATUS_NOT_INITIALIZED:
std::cerr << "CUBLAS_STATUS_NOT_INITIALIZED" << std::endl;
break;
case CUBLAS_STATUS_ALLOC_FAILED:
std::cerr << "CUBLAS_STATUS_ALLOC_FAILED" << std::endl;
break;
case CUBLAS_STATUS_INVALID_VALUE:
std::cerr << "CUBLAS_STATUS_INVALID_VALUE" << std::endl;
break;
case CUBLAS_STATUS_ARCH_MISMATCH:
std::cerr << "CUBLAS_STATUS_ARCH_MISMATCH" << std::endl;
break;
case CUBLAS_STATUS_MAPPING_ERROR:
std::cerr << "CUBLAS_STATUS_MAPPING_ERROR" << std::endl;
break;
case CUBLAS_STATUS_EXECUTION_FAILED:
std::cerr << "CUBLAS_STATUS_EXECUTION_FAILED" << std::endl;
break;
case CUBLAS_STATUS_INTERNAL_ERROR:
std::cerr << "CUBLAS_STATUS_INTERNAL_ERROR" << std::endl;
break;
case CUBLAS_STATUS_NOT_SUPPORTED:
std::cerr << "CUBLAS_STATUS_NOT_SUPPORTED" << std::endl;
break;
case CUBLAS_STATUS_LICENSE_ERROR:
std::cerr << "CUBLAS_STATUS_LICENSE_ERROR" << std::endl;
break;
default:
std::cerr << "Unknown cublas status" << std::endl;
exit(1);
int main() {
const int M = 4096;
const int N = 20480;
const int K = 5120;
// Allocate device memory
half *d_A, *d_B, *d_C;
CHECK_CUDA(cudaMalloc((void**)&d_A, M * K * sizeof(half)));
CHECK_CUDA(cudaMalloc((void**)&d_B, K * N * sizeof(half)));
CHECK_CUDA(cudaMalloc((void**)&d_C, M * N * sizeof(half)));
// Initialize matrices
initialize_matrix(d_A, M, K, __float2half(1.0f));
initialize_matrix(d_B, K, N, __float2half(1.0f));
initialize_matrix(d_C, M, N, __float2half(0.0f));
// Initialize cuBLAS
cublasHandle_t handle;
CHECK_CUBLAS(cublasCreate(&handle));
// Set cuBLAS to use Tensor Cores
CHECK_CUBLAS(cublasSetMathMode(handle, CUBLAS_TENSOR_OP_MATH));
// Define scaling factors
const half alpha = __float2half(1.0f);
const half beta = __float2half(0.0f);
// Perform matrix multiplication: C = alpha * A * B + beta * C
// A is M x K
// B is K x N
// C is M x N
auto start = std::chrono::high_resolution_clock::now();
cublasStatus_t status = cublasGemmEx(handle, CUBLAS_OP_N, CUBLAS_OP_N,
N, M, K,
&alpha,
d_B, CUDA_R_16F, N,
d_A, CUDA_R_16F, K,
&beta,
d_C, CUDA_R_16F, N,
CUDA_R_16F, CUBLAS_GEMM_DEFAULT_TENSOR_OP);
auto end = std::chrono::high_resolution_clock::now();
std::chrono::duration<float, std::milli> duration = end - start;
handle_cublas_status(status);
// Print the first element of the result matrix
print_first_element(d_C);
// Print the execution time
std::cout << "Execution time: " << duration.count() << " ms" << std::endl;
// Clean up
CHECK_CUDA(cudaFree(d_A));
CHECK_CUDA(cudaFree(d_B));
CHECK_CUDA(cudaFree(d_C));
CHECK_CUBLAS(cublasDestroy(handle));
std::cout << "Matrix multiplication completed successfully!" << std::endl;
return 0;
And I am curious that what is the difference between these two lines? Both are from L2 to shared memory…
output-file-full.nsight-cuprof-report.zip (40.3 MB)
