need consider synchronization problem?
in such function:
global func(int *count)
(*count)++;
need consider synchronization problem of *count? how to implement?
  1. 8600 supports atomic operation
  2. I implemented a lock on 8800 in
    http://forums.nvidia.com/index.php?showtopic=45458
    using customized compiler.
    It’s slow, and only works per block. You’d have to do a per-block reduction first.
  3. Convert to reduction, likely to be most efficient
