Jetson Orin supports only Jetpack 5.0 which has only cuda-11.4. I need earlier version of cuda for MXnet support. I am not able to find an easier solution around it. Can you please help?
There’re dependency in low layer driver, only the version from JetPack can be used.
Okay. In the installation steps of mxnet the makefile has -gencode arch=compute_72,code=sm_72
for Xavier NX and AGX Xavier`. Is it the same for AGX Orin as well?
Figured it out, for Orin modules it is 87
