Need help about inference on webcam stream
Hi. I am trying to use my webcam as a stream source. I’ve changed
camera-v4l2-dev-node=0
parameter to 1 placed under [source0] section of the PGIE-FP16-CarType-CarMake-CarColor.txt file. After this, when I start the nvgstiva-app-gui with
$ nvgstiva-app-gui -c /home/nvidia/configs/PGIE-FP16-CarType-CarMake-CarColor.txt -g /home/nvidia/configs/gui_cfg.txt
command, it opens the gui and my webcam’s LED blinks for 1 sec and goes off with the GUI. I think that i should increase the stream buffer but i don’t know how to do. How can I feed DeepStream with the live webcam stream? Thanks in advance.
Here is the log on terminal aftrer everything goes off:
** INFO: <bus_callback:123>: Pipeline running
libv4l2: error got 4 consecutive frame decode errors, last error: v4l-convert: error Invalid argument
Error from src_elem: Failed to allocate a buffer
Debug info: gstv4l2src.c(851): gst_v4l2src_create (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem
Error from src_elem: Internal data flow error.
Debug info: gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem:
streaming task paused, reason error (-5)
** INFO: <bus_callback:162>: Received EOS. Exiting …
Quitting
Exiting from gst_nv_caffe_inference_thread thread
App run failed
Please notice that this is DeepStream for Tesla board.
Could you share more information about the device you used?
Do you run DeepStream on the Jetson platform?
Sorry for wrong topic placement. Yes I am using TX2. I’ve changed csi sensor id in the config file and problem is gone. But I still have questions about how to use custom networks and how to create a config file for these networks (like sample config file).
You can find the corresponding information in our document:
[i][deepstream folder]/nviva_docs/index.html
Application Configuration[/i]
