Jetson
• DeepStream Version
6.0.1
4.6.1
• TensorRT Version
8.2.1
Questions, possible bug?
We’re trying to extend an our current implementation of a DeepStream/gstreamer RTSP decode source bin – that is based on your provided example in:
apps/apps-common/src/deepstream_source.bin.c
The current solution works well for H264 and H265 encoding, but we’d like to support RTSP/JPEG as well.
We’ve confirmed that the following launch command works with our cameras…
gst-launch-1.0 -vvv rtspsrc location=rtsp://192.168.1.140:554/jpeg ! rtpjpegdepay ! jpegparse ! nvjpegdec ! nveglglessink sync=0
The below code, although based on our own framework, should help to illustrate what we’re trying to do.
this is logic executed from the context of the rtspsrc
select-stream
callback function. The function simply loads specific plugin’s based on the encoding found… with a few extra log statements for the JPEG case.
bool RtspSourceBintr::HandleSelectStream(GstElement *pBin, uint num, GstCaps *caps)
GstStructure *structure = gst_caps_get_structure(caps, 0);
std::string media = gst_structure_get_string(structure, "media");
std::string encoding = gst_structure_get_string(structure, "encoding-name");
if (media.find("video") != std::string::npos)
if (encoding.find("H264") != std::string::npos)
m_pParser = DSL_ELEMENT_NEW("h264parse", GetCStrName());
m_pDepay = DSL_ELEMENT_NEW("rtph264depay", GetCStrName());
m_pDecodeBin = DSL_ELEMENT_NEW("decodebin", GetCStrName());
else if (encoding.find("H265") != std::string::npos)
m_pParser = DSL_ELEMENT_NEW("h265parse", GetCStrName());
m_pDepay = DSL_ELEMENT_NEW("rtph265depay", GetCStrName());
else if (encoding.find("JPEG") != std::string::npos)
m_pParser = DSL_ELEMENT_NEW("jpegparse", GetCStrName());
LOG_INFO("Define jpegparse");
m_pDepay = DSL_ELEMENT_NEW("rtpjpegdepay", GetCStrName());
LOG_INFO("Define rtpjpegdepay");
m_pDecodeBin = DSL_ELEMENT_NEW("nvjpegdec", GetCStrName());
LOG_INFO("Define nvjpegdec");
Again, the H264 and H265 case work fine. The JPEG case, however, leads to a segfault as show with the logs below
0:00:00.828271016 3696 0x56080aff6c00 INFO DSL src/DslSourceBintr.cpp:2632:HandleSelectStream: : Media = 'video' for RtspSourceBitnr 'rtsp-source'
0:00:00.828285478 3696 0x56080aff6c00 INFO DSL src/DslSourceBintr.cpp:2633:HandleSelectStream: : Encoding = 'JPEG' for RtspSourceBitnr 'rtsp-source'
0:00:00.828585566 3696 0x56080aff6c00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstjpegformat.so" loaded
0:00:00.828596836 3696 0x56080aff6c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "jpegparse" named "rtsp-source-jpegparse"
0:00:00.828646973 3696 0x56080aff6c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseParse@0x7f55e801ec40> adding pad 'sink'
0:00:00.828657730 3696 0x56080aff6c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseParse@0x7f55e801ec40> adding pad 'src'
0:00:00.828686082 3696 0x56080aff6c00 INFO DSL src/DslSourceBintr.cpp:2658:HandleSelectStream: : Define jpegparse
0:00:00.829178220 3696 0x56080aff6c00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtp.so" loaded
0:00:00.829186671 3696 0x56080aff6c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "rtpjpegdepay" named "rtsp-source-rtpjpegdepay"
0:00:00.829226547 3696 0x56080aff6c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstRTPBaseDepayload@0x7f55e8029e60> adding pad 'sink'
0:00:00.829239611 3696 0x56080aff6c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstRTPBaseDepayload@0x7f55e8029e60> adding pad 'src'
0:00:00.829255753 3696 0x56080aff6c00 INFO DSL src/DslSourceBintr.cpp:2660:HandleSelectStream: : Define rtpjpegdepay
0:00:00.830291341 3696 0x56080aff6c00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_jpegdec.so" loaded
0:00:00.830302014 3696 0x56080aff6c00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvjpegdec" named "rtsp-source-nvjpegdec"
0:00:00.830348805 3696 0x56080aff6c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoDecoder@0x7f55e80457e0> adding pad 'sink'
0:00:00.830358482 3696 0x56080aff6c00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoDecoder@0x7f55e80457e0> adding pad 'src'
It appears as if loading the nvjpegdec
plugin in the context of the rtspsrc stream-select
context is causing the fault.
My first questions are… before I spend time trying to reproduce the problem with you DS example code…
- do you have a working example for RTSP/JPEG?
- and do you know of any reason why this may be an issue?
Thanks,
Robert.
