Need help for cuda begginer Incrementing array example on linux
I am just started learning cuda. I need simple examples to understand programs. Could you give give me simple programs like incrementing an array or square first n numbers or find the sum of first n numbers
So that i could understand how to write .cu .cpp files I saw the programs in sdk they were hard to understand.
also i need instructions how to execute it on linux
Please help i am desperate to learn cuda, your reply is very valuable to me. thanks for your time
The SDK is your best friend :) well the programming guide also :)
You can probably start with the reduction or MatrixMul samples
eyal
eyal
