Can you please elaborate little bit
What am I missing here?
import numpy as np
from numba import cuda, types
@cuda.jit
def mm_shared(a, b, c):
# implemented similar to https://numba.pydata.org/numba-doc/dev/cuda/examples.html
# `a_cache` and `b_cache` are already correctly defined
a_cache = cuda.shared.array(block_size, types.int32)
b_cache = cuda.shared.array(block_size, types.int32)
row, col = cuda.grid(2)
stride_row, stride_col = cuda.gridsize(2)
thread_x = cuda.threadIdx.x
thread_y = cuda.threadIdx.y
if row >= c.shape[0] and col >= c.shape[1]:
# Quit if (row, col) is outside of valid C boundary
return
# TODO: use each thread to populate one element each a_cache and b_cache
sum = 0
for data_row in range(row, a.shape[0], stride_row):
for data_col in range(col, b.shape[1], stride_col):
for i in range(a.shape[1]):
# Preload data into shared memory
a_cache[thread_x][thread_y] = a[data_row][thread_y + i * N]
b_cache[thread_x][thread_y] = b[thread_x + i * N][data_col]
# Wait until all threads finish preloading
cuda.syncthreads()
# Compute partial product on the shared memory
for j in range(N):
# TODO: calculate the `sum` value correctly using values from the cache
sum += a_cache[thread_x][j] * b_cache[j][thread_y]
# Wait for all threads to finish computing
cuda.syncthreads()
c[data_row][data_col] = sum
I have tried everything and I believe the problem is getting the edges of shared memory to 0 out. Right now it still only works if M is whole-number divisible by N. What am I missing to imultiply the edges when M isn’t divisible by N?
Thank you, this was definitely helpful for better understanding.
Hi All,
The code given Examples — Numba 0.52.0.dev0+274.g626b40e-py3.7-linux-x86_64.egg documentation which consists of the blocked algorithm computing matrix multiplication, there seems to be a discrepancy when computing the result for matrices with unequal dimensions for example (1024,512) x (512,1024). Has anyone found any similar issues
