Kukusz
1
Hey Developers,
i try to decode a jpg file and convert it to yuv plane file.
Everything works fine, the Problem is that i get some kind of strange block artifacts.
I’ve tried different JPG files, but with my ones i will get that result, other works fine.
[url]url] - directupload.net
I looked through the JPG file with an analyzer, but i cant find any mistakes with the marker…
BTW: The Pictures comes from a security camera!
Thanks for help!
Best regards Kukusz
Each 8x8 block seems horizontally mirrored to me. hmm
Kukusz
3
Sounds good, but the complete Picture is just split by half and i dont know why…
I use the Inverted Discrete Cosine Transformation, maybe this is the Problem…
I’ve tried a new Image with two colored lines and one circle, but i cant figure out whats the
Problem!
what kind of YUV viewer is used in your screenshot?
Kukusz
5
i forgot where i download it. Its a standalone exe, search Google, for me it was easy to find…
BTW: i found the mistake but for the first i cant find the source of it. Maybe this jpeg is not
compatible with the inverted DCT
Maybe this particular YUV viewer expects the data in a different interleaving format than you feed it.
Or maybe it uses different chroma downsampling?
Christian
Kukusz
7
Nope, i solved it by recoding the 8x8 blocks through a lot of Iteration Loops. Little example
Picture: number = 8x8 pixelblock, | = middle of picture
1, 2| 3, 4 1,3|2,4 1,5|2,6
5, 6| 7, 8 → 5,7|6,8 → 3,7|4,8
9, 10| 11, 12 9,11|10,12 9,13|10,14
13, 14| 15, 16 13,15|14,16 11,15|12,16
- Comb left blocks with right block, then swap in every 2x2 block, left down with right up
Very strange that type of Decoding…
Greeting Chris
Kukusz
8
Sh*t sorry for the bad Format ;-)
