Folks, I’m hoping someone can help me with my attempts to learn how to use GStreamer on the TX2
To set the scene I’ve little to no experience of C beyond “Hello World”. I’ve a reasonable amount of experience using C# on Windows but I know this is a very different beast.
I’m making my way through the GStreamer tutorials and I’ve gotten stuck on tutorial 2, not a good sign. I’m probably making things more complex than they need to be because the standard steps in the tutorial don’t work on the Jetson but I figure I need to work this out.
The gst-launch pipeline that works on the Jetson is this
gst-launch-1.0 videotestsrc ! vertigotv ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)NV12' ! autovideosink
I can get this to run using C if I leave out the ‘vertigotv’ element but if I include it then I need to use ‘nvvidconv’ with parameters and that’s where the wheels start coming off. I can’t work out how to set the parameters on the ‘nvvidconv’ element.
I believe the relevant sections of code are
GstElement *pipeline, *source, *sink, *filter, *converter;
GstCaps *capsnvvidconv;
converter = gst_element_factory_make ("nvvidconv", "converter");
capsnvvidconv = gst_caps_from_string("video/x-raw(memory:NVMM), format=(string)NV12");
gst_bin_add_many (GST_BIN (pipeline), source, filter, converter, sink, NULL);
/* FAILS at the following block */
if (gst_element_link_filtered (filter, converter, capsnvvidconv) != TRUE ) {
g_printerr ("Second element link failed.\n");
gst_object_unref (pipeline);
return -1;
I’ve found this forum post noting that using creating CAPS using ‘(memory:NVMM)’ can be tricky so I’m following their suggestions (I think)
Full code below, any help greatly appreciated.
#include <gst/gst.h>
int
main (int argc, char *argv[])
GstBus *bus;
GstMessage *msg;
GstStateChangeReturn ret;
/* Initialize GStreamer */
gst_init (&argc, &argv);
/* Create the elements */
source = gst_element_factory_make ("videotestsrc", "source");
filter = gst_element_factory_make ("vertigotv", "filter");
sink = gst_element_factory_make ("autovideosink", "sink");
if(!capsnvvidconv) {
g_printerr ("Caps could not be created.\n");
return -1;
/* Create the empty pipeline */
pipeline = gst_pipeline_new ("test-pipeline");
if (!pipeline || !source || !sink) {
g_printerr ("Not all elements could be created.\n");
return -1;
/* Build the pipeline */
if (gst_element_link (source, filter) != TRUE ) {
g_printerr ("First element link failed.\n");
return -1;
return -1;
if (gst_element_link (converter, sink) != TRUE ) {
g_printerr ("Third element link failed.\n");
return -1;
/* Modify the source's properties */
g_object_set (source, "pattern", 0, NULL);
/* Start playing */
ret = gst_element_set_state (pipeline, GST_STATE_PLAYING);
if (ret == GST_STATE_CHANGE_FAILURE) {
g_printerr ("Unable to set the pipeline to the playing state.\n");
return -1;
/* Remaining error parsing and cleanup code omitted for brevity */
