Hi, all,
I have met one problem for the register and other resource occupancy analysis when applying DECUDA tool to analyze the elf-format cubin file.
The elf-format cubin file is not text format. So, I use the elfToCubin.py in DECUDA to change elf into readable cubin file. However, problem here is that the values of lmem, smem, reg and bar are always 0, i.e.
lmem=0
smem=0
reg=0
bar=0
But, the bincode is correctly demonstrated. Definitely, I use registers in my kernel function. (I paste my kernel function below):
global void matrixAdd_kernel( int **d_A, int **d_B, int **d_Result, int width)
int ix = blockDim.y * blockIdx.y + threadIdx.y;
int iy = blockDim.x * blockIdx.x + threadIdx.x;
for(int i=0;i<width;i++)
d_Result[ix][iy]+=d_A[ix][i] * d_B[i][iy];
} //end of kernel
Can anyone tell me how to get the right resource occupancy from elf-cubin file?
Some parameters setting: sm_12, cubda build rule 3.0.0.
