downloaded and installed Tegra210_Linux_R32.2.1_aarch64.tbz2 and Tegra_Linux_Sample-Root-Filesystem_R32.2.1_aarch64.tbz2.
It flash the but is trying to TFTP boot rather than booting form eMMC.
Any ideas?
----------- from Ubuntu 18.04 laptop -------------------------
tmap-dev1@tmap-Precision-7510:~/P3448-0020/Linux_for_Tegra$ ls
apply_binaries.sh jetson-nano-emmc.conf l4t_generate_soc_bup.sh p3448-0000.conf source_sync.sh
bootloader jetson-nano-qspi.conf lib p3448-0000.conf.common TX1_boot-firmware-redundancy.txt
build_l4t_bup.sh jetson-nano-qspi-sd.conf nv_tegra p3448-0000-emmc.conf
create-jetson-nano-sd-card-image.sh jetson-tx1.conf p2371-2180-devkit-24x7.conf p3448-0000-sd.conf
flash.sh kernel p2371-2180-devkit.conf rootfs
tmap-dev1@tmap-Precision-7510:~/P3448-0020/Linux_for_Tegra$ sudo ./flash.sh jetson-nano-emmc mmcblk0p1
L4T BSP Information:
R32 , REVISION: 2.1
Target Board Information:
Name: jetson-nano-emmc, Board Family: t210ref, SoC: Tegra 210,
OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x21 --applet “/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0069 ] Generating RCM messages
[ 0.0113 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0155 ] RCM 0 is saved as rcm_0.rcm
[ 0.0183 ] RCM 1 is saved as rcm_1.rcm
[ 0.0183 ] List of rcm files are saved in rcm_list.xml
[ 0.0183 ]
[ 0.0185 ] Signing RCM messages
[ 0.0229 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0272 ] Assuming zero filled SBK key
[ 0.0553 ]
[ 0.0554 ] Copying signature to RCM mesages
[ 0.0599 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0665 ]
[ 0.0667 ] Boot Rom communication
[ 0.0709 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0751 ] RCM version 0X210001
[ 0.1235 ] Boot Rom communication completed
[ 1.1310 ]
[ 1.1314 ] dump EEPROM info
[ 1.1363 ] tegrarcm --oem platformdetails eeprom /home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1409 ] Applet version 00.01.0000
[ 1.1608 ] Saved platform info in /home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/cvm.bin
[ 1.2376 ]
Board ID(3448) version(400)
creating dummy /home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/badpage.bin
1+0 records in
1+0 records out
4096 bytes (4.1 kB, 4.0 KiB) copied, 0.000561747 s, 7.3 MB/s
copying bctfile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)… done.
copying bootloader(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying initrd(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating /home/tmap-dev1/P3448-0020/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb to rootfs… done.
Making Boot image… done.
Existing sosfile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
copying cpu_bootloader(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying bpffile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
Existing badpagefile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)… done.
Copying nv_boot_control.conf to rootfs
Making system.img…
populating rootfs from /home/tmap-dev1/P3448-0020/Linux_for_Tegra/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 7340032( 7 blks) ==> 28:7340044
1: SKP: 30408704( 29 blks) ==> 7340072:12
2: RAW: 3145728( 3 blks) ==> 7340084:3145740
3: SKP: 93323264( 89 blks) ==> 10485824:12
4: RAW: 1048576( 1 blks) ==> 10485836:1048588
5: SKP: 3145728( 3 blks) ==> 11534424:12
6: RAW: 77594624( 74 blks) ==> 11534436:77594636
7: SKP: 1048576( 1 blks) ==> 89129072:12
8: RAW: 186646528( 178 blks) ==> 89129084:186646540
9: SKP: 3145728( 3 blks) ==> 275775624:12
10: RAW: 265289728( 253 blks) ==> 275775636:265289740
11: SKP: 3145728( 3 blks) ==> 541065376:12
12: RAW: 265289728( 253 blks) ==> 541065388:265289740
13: SKP: 3145728( 3 blks) ==> 806355128:12
14: RAW: 265289728( 253 blks) ==> 806355140:265289740
15: SKP: 3145728( 3 blks) ==> 1071644880:12
16: RAW: 629145600( 600 blks) ==> 1071644892:629145612
17: SKP: 1048576( 1 blks) ==> 1700790504:12
18: RAW: 309329920( 295 blks) ==> 1700790516:309329932
19: SKP: 29360128( 28 blks) ==> 2010120448:12
20: RAW: 23068672( 22 blks) ==> 2010120460:23068684
21: SKP: 77594624( 74 blks) ==> 2033189144:12
22: RAW: 167772160( 160 blks) ==> 2033189156:167772172
23: SKP: 33554432( 32 blks) ==> 2200961328:12
24: RAW: 5242880( 5 blks) ==> 2200961340:5242892
25: SKP: 3145728( 3 blks) ==> 2206204232:12
26: RAW: 141557760( 135 blks) ==> 2206204244:141557772
27: SKP: 1048576( 1 blks) ==> 2347762016:12
28: RAW: 32505856( 31 blks) ==> 2347762028:32505868
29: SKP: 1048576( 1 blks) ==> 2380267896:12
30: RAW: 40894464( 39 blks) ==> 2380267908:40894476
31: SKP: 1048576( 1 blks) ==> 2421162384:12
32: RAW: 47185920( 45 blks) ==> 2421162396:47185932
33: SKP: 3145728( 3 blks) ==> 2468348328:12
34: RAW: 22020096( 21 blks) ==> 2468348340:22020108
35: SKP: 3145728( 3 blks) ==> 2490368448:12
36: RAW: 39845888( 38 blks) ==> 2490368460:39845900
37: SKP: 2097152( 2 blks) ==> 2530214360:12
38: RAW: 79691776( 76 blks) ==> 2530214372:79691788
39: SKP: 4194304( 4 blks) ==> 2609906160:12
40: RAW: 80740352( 77 blks) ==> 2609906172:80740364
41: SKP: 3145728( 3 blks) ==> 2690646536:12
42: RAW: 40894464( 39 blks) ==> 2690646548:40894476
43: SKP: 1048576( 1 blks) ==> 2731541024:12
44: RAW: 15728640( 15 blks) ==> 2731541036:15728652
45: SKP: 1048576( 1 blks) ==> 2747269688:12
46: RAW: 28311552( 27 blks) ==> 2747269700:28311564
47: SKP: 1048576( 1 blks) ==> 2775581264:12
48: RAW: 26214400( 25 blks) ==> 2775581276:26214412
49: SKP: 3145728( 3 blks) ==> 2801795688:12
50: RAW: 33554432( 32 blks) ==> 2801795700:33554444
51: SKP: 1048576( 1 blks) ==> 2835350144:12
52: RAW: 39845888( 38 blks) ==> 2835350156:39845900
53: SKP: 1048576( 1 blks) ==> 2875196056:12
54: RAW: 15728640( 15 blks) ==> 2875196068:15728652
55: SKP: 1048576( 1 blks) ==> 2890924720:12
56: RAW: 8388608( 8 blks) ==> 2890924732:8388620
57: SKP: 8388608( 8 blks) ==> 2899313352:12
58: RAW: 5242880( 5 blks) ==> 2899313364:5242892
59: SKP: 128974848( 123 blks) ==> 2904556256:12
60: RAW: 1048576( 1 blks) ==> 2904556268:1048588
61: SKP: 267386880( 255 blks) ==> 2905604856:12
62: RAW: 1048576( 1 blks) ==> 2905604868:1048588
63: SKP: 670040064( 639 blks) ==> 2906653456:12
64: RAW: 5242880( 5 blks) ==> 2906653468:5242892
65: SKP: 28311552( 27 blks) ==> 2911896360:12
66: RAW: 8388608( 8 blks) ==> 2911896372:8388620
67: SKP: 92274688( 88 blks) ==> 2920284992:12
68: RAW: 90177536( 86 blks) ==> 2920285004:90177548
69: SKP: 1048576( 1 blks) ==> 3010462552:12
70: RAW: 343932928( 328 blks) ==> 3010462564:343932940
71: SKP: 1578106880( 1505 blks) ==> 3354395504:12
72: RAW: 7340032( 7 blks) ==> 3354395516:7340044
73: SKP: 26214400( 25 blks) ==> 3361735560:12
74: RAW: 4194304( 4 blks) ==> 3361735572:4194316
75: SKP: 96468992( 92 blks) ==> 3365929888:12
76: RAW: 1048576( 1 blks) ==> 3365929900:1048588
77: SKP: 3145728( 3 blks) ==> 3366978488:12
78: RAW: 197132288( 188 blks) ==> 3366978500:197132300
79: SKP: 33554432( 32 blks) ==> 3564110800:12
80: RAW: 33554432( 32 blks) ==> 3564110812:33554444
81: SKP: 1744830464( 1664 blks) ==> 3597665256:12
82: RAW: 6291456( 6 blks) ==> 3597665268:6291468
83: SKP: 27262976( 26 blks) ==> 3603956736:12
84: RAW: 10485760( 10 blks) ==> 3603956748:10485772
85: SKP: 90177536( 86 blks) ==> 3614442520:12
86: RAW: 1186988032( 1132 blks) ==> 3614442532:1186988044
87: SKP: 826277888( 788 blks) ==> 4801430576:12
88: RAW: 5242880( 5 blks) ==> 4801430588:5242892
89: SKP: 28311552( 27 blks) ==> 4806673480:12
90: RAW: 11534336( 11 blks) ==> 4806673492:11534348
91: SKP: 89128960( 85 blks) ==> 4818207840:12
92: RAW: 1048576( 1 blks) ==> 4818207852:1048588
93: SKP: 3145728( 3 blks) ==> 4819256440:12
94: RAW: 174063616( 166 blks) ==> 4819256452:174063628
95: SKP: 23068672( 22 blks) ==> 4993320080:12
96: RAW: 33554432( 32 blks) ==> 4993320092:33554444
97: SKP: 1778384896( 1696 blks) ==> 5026874536:12
98: RAW: 5242880( 5 blks) ==> 5026874548:5242892
99: SKP: 28311552( 27 blks) ==> 5032117440:12
100: RAW: 10485760( 10 blks) ==> 5032117452:10485772
101: SKP: 90177536( 86 blks) ==> 5042603224:12
102: RAW: 167772160( 160 blks) ==> 5042603236:167772172
103: SKP: 33554432( 32 blks) ==> 5210375408:12
104: RAW: 16777216( 16 blks) ==> 5210375420:16777228
105: SKP: 1795162112( 1712 blks) ==> 5227152648:12
– Total: ---------------------------------------------------
106 CHUNK 15032385536( 14336 blks) ==> 5227152660(4985 blks)
done.
system.img built successfully.
Existing tbcfile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0002-p3449-0000-b00.dtb)… done.
copying cfgfile(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_emmc_p3448.xml) to flash.xml… done.
copying flasher(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
Existing flashapp(/home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0002-p3449-0000-b00.dtb --applet nvtboot_recovery.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x21 --bins “EBT cboot.bin; DTB tegra210-p3448-0002-p3449-0000-b00.dtb”
saving flash command in /home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/tmap-dev1/P3448-0020/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.1902 ] tegrasign --key None --getmode mode.txt
[ 0.1946 ] Assuming zero filled SBK key
[ 0.1955 ]
[ 0.1957 ] Generating RCM messages
[ 5.0654 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 5.0696 ] RCM 0 is saved as rcm_0.rcm
[ 5.0718 ] RCM 1 is saved as rcm_1.rcm
[ 5.0719 ] List of rcm files are saved in rcm_list.xml
[ 5.0719 ]
[ 5.0720 ] Signing RCM messages
[ 5.0762 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 5.0801 ] Assuming zero filled SBK key
[ 5.1106 ]
[ 5.1107 ] Copying signature to RCM mesages
[ 5.1152 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 5.2003 ]
[ 5.2005 ] Parsing partition layout
[ 5.5230 ] tegraparser --pt flash.xml.tmp
[ 5.5285 ]
[ 5.5287 ] Creating list of images to be signed
[ 10.1661 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 10.3329 ]
[ 10.3330 ] Generating signatures
[ 10.3374 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 10.3413 ] Assuming zero filled SBK key
[ 10.6102 ]
[ 10.6104 ] Generating br-bct
[ 10.8528 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 10.8571 ] Copying Sdram info from 0 to 1 set
[ 10.8626 ] Copying Sdram info from 1 to 2 set
[ 10.8626 ] Copying Sdram info from 2 to 3 set
[ 10.8626 ]
[ 10.8627 ] Updating boot device parameters
[ 10.8669 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 10.8709 ] Warning: No sdram params
[ 11.0323 ]
[ 11.0324 ] Updating bl info
[ 11.0374 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 11.2408 ]
[ 11.2410 ] Updating secondary storage information into bct
[ 11.2454 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 11.3444 ]
[ 11.3446 ] Updating Odmdata
[ 11.3489 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 11.3528 ] Warning: No sdram params
[ 11.4482 ]
[ 11.4484 ] Get Signed section of bct
[ 11.4527 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 11.4572 ]
[ 11.4573 ] Signing BCT
[ 11.4654 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 11.4695 ] Assuming zero filled SBK key
[ 11.4716 ]
[ 11.4717 ] Updating BCT with signature
[ 11.4758 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 11.5524 ]
[ 11.5527 ] Copying signatures
[ 11.5572 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 11.8633 ]
[ 11.8636 ] Updating BFS information on BCT
[ 11.8680 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 11.8719 ] BFS:
[ 11.8905 ] 0: [PT ] flash.xml.bin (size=2306/65536)
[ 11.8922 ] 2: [VER] emmc_bootblob_ver.txt (size=57/65536)
[ 11.8942 ] BFS0: 65536 @ 896 SUM 79457a5e over 7929856 bytes
[ 11.9683 ]
[ 11.9685 ] Boot Rom communication
[ 11.9729 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 11.9768 ] BootRom is not running
[ 12.0206 ]
[ 12.0208 ] Sending BCTs
[ 12.0253 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 12.0296 ] Applet version 00.01.0000
[ 12.0525 ] Sending bct
[ 12.0531 ] […] 100%
[ 12.2260 ]
[ 12.2313 ] tegrahost --chip 0x21 --align cboot.bin
[ 12.2357 ]
[ 12.2400 ] tegrahost --magicid EBT --appendsigheader cboot.bin cboot.bin_blheader
[ 12.3191 ]
[ 12.3246 ] tegrasign --key None --list cboot.bin_list.xml
[ 12.3285 ] Assuming zero filled SBK key
[ 12.4081 ]
[ 12.4144 ] tegrahost --updatesigheader cboot.bin_blheader.encrypt cboot.bin_blheader.hash zerosbk
[ 12.5563 ]
[ 12.5722 ] tegrahost --chip 0x21 --align tegra210-p3448-0002-p3449-0000-b00.dtb
[ 12.5764 ]
[ 12.5814 ] tegrahost --magicid DTB --appendsigheader tegra210-p3448-0002-p3449-0000-b00.dtb tegra210-p3448-0002-p3449-0000-b00.dtb_blheader
[ 12.6709 ]
[ 12.6772 ] tegrasign --key None --list tegra210-p3448-0002-p3449-0000-b00.dtb_list.xml
[ 12.6812 ] Assuming zero filled SBK key
[ 12.7161 ]
[ 12.7222 ] tegrahost --updatesigheader tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.encrypt tegra210-p3448-0002-p3449-0000-b00.dtb_blheader.hash zerosbk
[ 12.7793 ]
[ 12.7820 ] Sending bootloader and pre-requisite binaries
[ 12.7867 ] tegrarcm --download ebt cboot.bin.encrypt 0 0 --download rp1 tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt 0
[ 12.7906 ] Applet version 00.01.0000
[ 12.8123 ] Sending ebt
[ 12.8130 ] […] 100%
[ 12.9239 ] Sending rp1
[ 12.9283 ] […] 100%
[ 12.9802 ]
[ 12.9850 ] tegrarcm --boot recovery
[ 12.9896 ] Applet version 00.01.0000
[ 13.0083 ]
[ 13.0085 ] Retrieving storage infomation
[ 13.0138 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 13.0184 ] Applet is not running on device. Continue with Bootloader
[ 13.5952 ]
[ 13.6878 ] tegradevflash --oem platformdetails storage storage_info.bin
[ 13.6918 ] Cboot version 00.01.0000
[ 13.7220 ] Saved platform info in storage_info.bin
[ 13.7328 ]
[ 13.7330 ] Flashing the device
[ 13.7375 ] tegradevflash --pt flash.xml.bin --storageinfo storage_info.bin --create
[ 13.7422 ] Cboot version 00.01.0000
[ 13.7465 ] Writing partition GPT with gpt.bin
[ 13.7477 ] […] 100%
[ 13.7524 ] Writing partition NVC with nvtboot.bin.encrypt
[ 14.3297 ] […] 100%
[ 14.3413 ] Writing partition PT with flash.xml.bin
[ 14.3653 ] […] 100%
[ 14.3708 ] Writing partition VER with emmc_bootblob_ver.txt
[ 14.3935 ] […] 100%
[ 14.4103 ] Writing partition APP with system.img
[ 14.4592 ] […] 100%
[ 234.3124 ] Writing partition TBC with nvtboot_cpu.bin.encrypt
[ 235.6054 ] […] 100%
[ 235.6185 ] Writing partition RP1 with tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 235.6565 ] […] 100%
[ 235.6741 ] Writing partition EBT with cboot.bin.encrypt
[ 235.7116 ] […] 100%
[ 235.7416 ] Writing partition WB0 with warmboot.bin.encrypt
[ 235.7834 ] […] 100%
[ 235.7938 ] Writing partition BPF with sc7entry-firmware.bin.encrypt
[ 235.8293 ] […] 100%
[ 235.8396 ] Writing partition TOS with tos-mon-only.img.encrypt
[ 235.8749 ] […] 100%
[ 235.8874 ] Writing partition DTB with tegra210-p3448-0002-p3449-0000-b00.dtb.encrypt
[ 235.9237 ] […] 100%
[ 235.9418 ] Writing partition LNX with boot.img.encrypt
[ 235.9805 ] […] 100%
[ 236.0101 ] Warning: EKS partition magic header mismatch!
[ 236.0392 ] Writing partition EKS with eks.img
[ 236.0404 ] […] 100%
[ 236.0499 ] Writing partition BMP with bmp.blob
[ 236.0852 ] […] 100%
[ 236.1176 ] Writing partition RP4 with rp4.blob
[ 236.1533 ] […] 100%
[ 236.2094 ]
[ 236.2140 ] tegradevflash --write BCT P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 236.2190 ] Cboot version 00.01.0000
[ 236.2231 ] Writing partition BCT with P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 236.2260 ] […] 100%
[ 236.3299 ]
[ 236.3300 ] Flashing completed
[ 236.3303 ] Coldbooting the device
[ 236.3346 ] tegradevflash --reboot coldboot
[ 236.3388 ] Cboot version 00.01.0000
[ 236.3428 ]
*** The target t210ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
– Nano Console log
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.10.24 21:32:07 =~=~=~=~=~=~=~=~=~=~=~=
\00[0399.834] Enabled early print
[0399.837] [TegraBoot] (version 00.00.2018.01-l4t-9867942c)
[0399.842] Processing in recovery mode
[0399.845] A02 Bootrom Patch rev = 1023
[0399.849] Power-up reason: pmc por
[0399.852] Established communication link with host
[0400.860] NvTbootI2cWrite(): error code 0x00045100 Error while starting write transaction
[0400.868] NvTbootI2cDeviceRead(): error code 0x00045001 Error while sending the offset to slave
[0400.876] NvTbootI2c: Read failed for slave 0xac, offset 0x00 with error code 0x00045001
[0557.762] Odmdata from BCT: 0x00094000
[0557.766] DebugPort= 0x3
[0557.775] BoardId read from EEPROM/NCT: 3448
[0557.779] BoardID = 3448, SKU = 0x2
[0557.806] NvTbootInit_Porg: Setting GPIO_A6 for HDMI …
[0557.811] No Battery Present
[0557.814] RamCode = 0
[0557.817] Platform has DDR4 type RAM
[0557.820] max77620 disabling SD1 Remote Sense
[0557.824] Setting DDR voltage to 1125mv
[0557.828] Serial Number of Pmic Max77663: 0xe0ff1
[0557.836] Entering ramdump check
[0557.839] Get RamDumpCarveOut = 0x0
[0557.842] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0557.847] Last reboot was clean, booting normally!
[0557.852] Sdram initialization is successful
[0557.856] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0557.862] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0557.868] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0557.874] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0557.880] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0557.886] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0557.892] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0557.898] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0557.914] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0557.920] Platform-DebugCarveout: 0
[0557.923] Downloaded BCT successfully
[0558.608] Downloaded Bootloader successfully
[0558.660] Downloaded rp1 successfully
[0558.692] MAX77620_GPIO5 configured
[0558.695] CPU power rail is up
[0558.698] CPU clock enabled
[0558.702] Performing RAM repair
[0558.705] Updating A64 Warmreset Address to 0x92c002e9
[0558.711] Enable APE clock/reset
[0558.714] Error in NvTbootGetTOSBinaryLength: 0x11 !
[0558.719] Loading Secure OS image failed.
[0558.723] Set NvDecSticky Bits
[0558.727] GSC2 address ff53fffc value c0edbbcc
[0558.733] GSC MC Settings done
[0558.737] Next binary entry address: 0x92c00258
[0558.742] BoardId: 3448
[0558.744] Overriding pmu board id with proc board id
[0558.749] Display board id is not available
[0558.753] Starting CPU & Halting co-processor
[0572.174]
[0572.175] Debug Init done
[0572.179] Marked DTB cacheable
[0572.182] Bootloader DTB loaded at 0x83000400
[0572.186] DeviceTree Init done
[0572.197] Pinmux applied successfully
[0572.202] gicd_base: 0x50041000
[0572.205] gicc_base: 0x50042000
[0572.208] Interrupts Init done
[0572.212] Using base:0x60005090 & irq:208 for tick-timer
[0572.217] Using base:0x60005098 for delay-timer
[0572.222] platform_init_timer: DONE
[0572.225] Timer(tick) Init done
[0572.229] osc freq = 38400 khz
[0572.233]
[0572.234] welcome to cboot
[0572.237]
[0572.238] Cboot Version: 00.00.2018.01-t210-3a168c35
[0572.243] calling constructors
[0572.246] initializing heap
[0572.249] initializing threads
[0572.252] initializing timers
[0572.254] creating bootstrap completion thread
[0572.259] top of bootstrap2()
[0572.262] CPU: ARM Cortex A57
[0572.265] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0572.269] initializing platform
[0572.272] Scratch reg 37 & 271 initial value set…
[0572.279] cboot:secure-pmc present
[0572.377] config for ddr50 mode completed
[0572.381] sdmmc bdev is already initialized
[0572.385] of_register: registering tegra_udc to of_hal
[0572.390] of_register: registering tegra_udc to of_hal
[0572.395] of_register: registering inv20628-driver to of_hal
[0572.400] of_register: registering ads1015-driver to of_hal
[0572.406] of_register: registering lp8557-bl-driver to of_hal
[0572.412] of_register: registering bq2419x_charger to of_hal
[0572.417] of_register: registering cpc to of_hal
[0572.422] of_register: registering bq27441_fuel_gauge to of_hal
[0572.434] gpio framework initialized
[0572.437] of_register: registering tca9539_gpio to of_hal
[0572.442] of_register: registering tca9539_gpio to of_hal
[0572.448] of_register: registering i2c_bus_driver to of_hal
[0572.453] of_register: registering i2c_bus_driver to of_hal
[0572.459] of_register: registering i2c_bus_driver to of_hal
[0572.464] of_register: registering i2c_bus_driver to of_hal
[0572.470] pmic framework initialized
[0572.473] of_register: registering max77620_pmic to of_hal
[0572.479] regulator framework initialized
[0572.483] of_register: registering tps65132_bl_driver to of_hal
[0572.489] initializing target
[0572.495] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0572.503] fixed regulator driver initialized
[0572.520] initializing OF layer
[0572.524] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0572.542] I2C Bus Init done
[0572.544] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0572.554] I2C Bus Init done
[0572.557] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0572.567] I2C Bus Init done
[0572.570] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0572.580] I2C Bus Init done
[0572.583] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0572.593] I2C Bus Init done
[0572.596] of_children_init: Ops found for compatible string maxim,max77620
[0572.606] max77620_init using irq 118
[0572.611] register ‘maxim,max77620’ pmic
[0572.615] gpio_driver_register: register ‘max77620-gpio’ driver
[0572.622] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0572.632] I2C Bus Init done
[0572.636] Applying platform configs
[0572.642] platform-init is not present. Skipping
[0572.647] calling apps_init()
[0572.663] Found 14 GPT partitions in “sdmmc3_user”
[0572.668] Proceeding to flashing Server
[0572.672] usbdcd_reinit Initialize driver to use already enumerated device
[0572.678] nv3p_priv_usbf_open USB configuration success
[0572.839] Writing GPT partition
[0572.843] Erasing Boot device
[0572.845] device_write_gpt: Erasing boot device sdmmc3_boot
[0572.880] Erasing Storage Device
[0573.334] Sanitizing Storage Device
[0573.343] Writing protective mbr
[0573.353] Writing primary GPT
[0573.392] Writing secondary GPT
[0573.414] Found 14 GPT partitions in “sdmmc3_user”
[0573.421] Writing NVC partition
[0573.451] partition NVC write successful.
[0573.457] Writing PT partition
[0573.479] partition PT write successful.
[0573.484] Writing VER partition
[0573.545] partition VER write successful.
[0573.550] Writing APP partition
[0602.605] max77620_clear_syswdt clearing watchdog
[0632.605] max77620_clear_syswdt clearing watchdog
[0662.605] max77620_clear_syswdt clearing watchdog
[0692.605] max77620_clear_syswdt clearing watchdog
[0722.605] max77620_clear_syswdt clearing watchdog
[0752.605] max77620_clear_syswdt clearing watchdog
[0782.606] max77620_clear_syswdt clearing watchdog
[0794.686] partition APP write successful.
[0794.692] Writing TBC partition
[0794.737] partition TBC write successful.
[0794.742] Writing RP1 partition
[0794.792] partition RP1 write successful.
[0794.798] Writing EBT partition
[0794.864] partition EBT write successful.
[0794.870] Writing WB0 partition
[0794.910] partition WB0 write successful.
[0794.915] Writing BPF partition
[0794.956] partition BPF write successful.
[0794.961] Writing TOS partition
[0795.004] partition TOS write successful.
[0795.009] Writing DTB partition
[0795.062] partition DTB write successful.
[0795.067] Writing LNX partition
[0795.120] partition LNX write successful.
[0795.126] Writing EKS partition
[0795.166] partition EKS write successful.
[0795.172] Writing BMP partition
[0795.234] partition BMP write successful.
[0795.240] Writing RP4 partition
[0795.291] partition RP4 write successful.
[0795.310] Writing BCT partition
[0795.411] partition BCT write successful.
[0795.430] Scratch 37 initial value set…
[0795.434] Change state to cold boot mode
[0795.437] Flushing data to stroage
[0000.204] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.210] Processing in cold boot mode Bootloader 2
[0000.214] A02 Bootrom Patch rev = 1023
[0000.218] Power-up reason: software reset
[0000.222] No Battery Present
[0000.224] pmic max77620 reset reason
[0000.228] pmic max77620 NVERC : 0x0
[0000.231] RamCode = 0
[0000.233] Platform has DDR4 type RAM
[0000.237] max77620 disabling SD1 Remote Sense
[0000.241] Setting DDR voltage to 1125mv
[0000.245] Serial Number of Pmic Max77663: 0xe0ff1
[0000.252] Entering ramdump check
[0000.255] Get RamDumpCarveOut = 0x0
[0000.258] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.264] Last reboot was clean, booting normally!
[0000.268] Sdram initialization is successful
[0000.272] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.278] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.284] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.290] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.296] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.302] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.308] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.313] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.330] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.336] Platform-DebugCarveout: 0
[0000.339] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.345] Non secure mode, and RB not enabled.
[0000.361] Csd NumOfBlocks=0
[0000.370] Using GPT Primary to query partitions
[0000.374] Loading Tboot-CPU binary
[0000.384] Verifying TBC in OdmNonSecureSBK mode
[0000.394] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.401] Bootloader downloaded successfully.
[0000.405] Downloaded Tboot-CPU binary to 0xa0000258
[0000.410] MAX77620_GPIO5 configured
[0000.413] CPU power rail is up
[0000.416] CPU clock enabled
[0000.420] Performing RAM repair
[0000.423] Updating A64 Warmreset Address to 0xa00002e9
[0000.428] Loading NvTbootBootloaderDTB
[0000.444] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.509] Bootloader DTB Load Address: 0x83000000
[0000.514] Loading NvTbootKernelDTB
[0000.528] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.593] Kernel DTB Load Address: 0x83100000
[0000.598] Loading cboot binary
[0000.614] Verifying EBT in OdmNonSecureSBK mode
[0000.656] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.663] Bootloader downloaded successfully.
[0000.670] Using BFS PT to query partitions
[0000.674] Next binary entry address: 0x92c00258
[0000.679] BoardId: 3448
[0000.683] Overriding pmu board id with proc board id
[0000.688] Display board id is not available
[0000.710] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.762] /bpmp deleted
[0000.764] SC7EntryFw header found loaded at 0xff700000
[0000.952] OVR2 PMIC
[0000.954] Bpmp FW successfully loaded
[0000.959] WB0 init successfully at 0xff780000
[0000.963] Set NvDecSticky Bits
[0000.967] GSC2 address ff53fffc value c0edbbcc
[0000.973] GSC MC Settings done
[0000.976] TOS Image length 53680
[0000.979] Monitor size 53680
[0000.982] OS size 0
[0000.988] Secure Os AES-CMAC Verification Success!
[0000.992] TOS image cipher info: plaintext
[0000.996] Loading and Validation of Secure OS Successful
[0001.012] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.017] NvTbootPackSdramParams: start.
[0001.022] NvTbootPackSdramParams: done.
[0001.026] Tegraboot started after 133838 us
[0001.030] Basic modules init took 575480 us
[0001.034] Sec Bootdevice Read Time = 69 ms, Read Size = 2292 KB
[0001.039] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.045] Next stage binary read took 18158 us
[0001.049] Carveout took -29858 us
[0001.052] CPU initialization took 353148 us
[0001.056] Total time taken by TegraBoot 916928 us
[0001.061] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 21:10:01, Aug 12 2019
ERROR: Error initializing runtime service trusty_fast
[0001.183] RamCode = 0
[0001.188] LPDDR4 Training: Read DT: Number of tables = 2
[0001.193] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.206] EMC Training Successful
[0001.209] 408000 not found in DVFS table
[0001.215] RamCode = 0
[0001.219] DT Write: emc-table@204000 succeeded
[0001.224] DT Write: emc-table@1600000 succeeded
[0001.228] LPDDR4 Training: Write DT: Number of tables = 2
[0001.267]
[0001.268] Debug Init done
[0001.270] Marked DTB cacheable
[0001.273] Bootloader DTB loaded at 0x83000000
[0001.278] Marked DTB cacheable
[0001.281] Kernel DTB loaded at 0x83100000
[0001.285] DeviceTree Init done
[0001.296] Pinmux applied successfully
[0001.301] gicd_base: 0x50041000
[0001.304] gicc_base: 0x50042000
[0001.307] Interrupts Init done
[0001.311] Using base:0x60005090 & irq:208 for tick-timer
[0001.316] Using base:0x60005098 for delay-timer
[0001.321] platform_init_timer: DONE
[0001.324] Timer(tick) Init done
[0001.328] osc freq = 38400 khz
[0001.332]
[0001.333] welcome to cboot
[0001.336]
[0001.337] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.342] calling constructors
[0001.345] initializing heap
[0001.348] initializing threads
[0001.351] initializing timers
[0001.353] creating bootstrap completion thread
[0001.358] top of bootstrap2()
[0001.361] CPU: ARM Cortex A57
[0001.364] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.368] initializing platform
[0001.371] Scratch reg 37 & 271 initial value set…
[0001.378] cboot:secure-pmc present
[0001.427] config for ddr50 mode completed
[0001.431] sdmmc bdev is already initialized
[0001.435] Enable APE clock
[0001.438] Un-powergate APE partition
[0001.441] of_register: registering tegra_udc to of_hal
[0001.447] of_register: registering tegra_udc to of_hal
[0001.452] of_register: registering inv20628-driver to of_hal
[0001.457] of_register: registering ads1015-driver to of_hal
[0001.463] of_register: registering lp8557-bl-driver to of_hal
[0001.469] of_register: registering bq2419x_charger to of_hal
[0001.474] of_register: registering cpc to of_hal
[0001.479] of_register: registering bq27441_fuel_gauge to of_hal
[0001.490] gpio framework initialized
[0001.494] of_register: registering tca9539_gpio to of_hal
[0001.499] of_register: registering tca9539_gpio to of_hal
[0001.504] of_register: registering i2c_bus_driver to of_hal
[0001.510] of_register: registering i2c_bus_driver to of_hal
[0001.515] of_register: registering i2c_bus_driver to of_hal
[0001.521] of_register: registering i2c_bus_driver to of_hal
[0001.527] pmic framework initialized
[0001.530] of_register: registering max77620_pmic to of_hal
[0001.536] regulator framework initialized
[0001.539] of_register: registering tps65132_bl_driver to of_hal
[0001.545] initializing target
[0001.551] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.560] fixed regulator driver initialized
[0001.577] initializing OF layer
[0001.580] NCK carveout not present
[0001.583] Skipping dts_overrides
[0001.587] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.604] I2C Bus Init done
[0001.606] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.616] I2C Bus Init done
[0001.619] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.629] I2C Bus Init done
[0001.632] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.642] I2C Bus Init done
[0001.645] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.655] I2C Bus Init done
[0001.658] of_children_init: Ops found for compatible string maxim,max77620
[0001.668] max77620_init using irq 118
[0001.673] register ‘maxim,max77620’ pmic
[0001.677] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.683] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.694] I2C Bus Init done
[0001.697] NCK carveout not present
[0001.700] shim_invoke: No NCT, Calling dts updates
[0001.712] Find /i2c@7000c000’s alias i2c0
[0001.716] get eeprom at 1-a0, size 256, type 0
[0001.724] Find /i2c@7000c500’s alias i2c2
[0001.728] get eeprom at 3-a0, size 256, type 0
[0001.733] get eeprom at 3-ae, size 256, type 0
[0001.737] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.742] I2C slave not started
[0001.745] I2C write failed
[0001.748] Writing offset failed
[0001.751] eeprom_init: EEPROM read failed
[0001.755] pm_ids_update: eeprom init failed
[0001.759] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.789] pm_ids_update: The pm board id is 3448-0002-400
[0001.796] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0001.804] pm_ids_update: pm id update successful
[0001.808] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.813] I2C slave not started
[0001.816] I2C write failed
[0001.819] Writing offset failed
[0001.822] eeprom_init: EEPROM read failed
[0001.826] pm_ids_update: eeprom init failed
[0001.856] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.862] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.870] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.876] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.885] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:dd:fd
[0001.891] Plugin Manager: Parse ODM data 0x00094000
[0001.901] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0001.922] Find /i2c@7000c000’s alias i2c0
[0001.926] get eeprom at 1-a0, size 256, type 0
[0001.935] Find /i2c@7000c500’s alias i2c2
[0001.938] get eeprom at 3-a0, size 256, type 0
[0001.943] get eeprom at 3-ae, size 256, type 0
[0001.947] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.953] I2C slave not started
[0001.956] I2C write failed
[0001.958] Writing offset failed
[0001.961] eeprom_init: EEPROM read failed
[0001.965] pm_ids_update: eeprom init failed
[0001.969] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.999] pm_ids_update: The pm board id is 3448-0002-400
[0002.006] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.013] pm_ids_update: pm id update successful
[0002.017] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.023] I2C slave not started
[0002.026] I2C write failed
[0002.028] Writing offset failed
[0002.031] eeprom_init: EEPROM read failed
[0002.035] pm_ids_update: eeprom init failed
[0002.066] Chip UID is 00000001644475c9000000000afd8140
[0002.071] Add serial number:142281901831304081fd as DT property
[0002.079] Applying platform configs
[0002.085] platform-init is not present. Skipping
[0002.090] calling apps_init()
[0002.106] Found 14 GPT partitions in “sdmmc3_user”
[0002.110] Proceeding to Cold Boot
[0002.114] starting app android_boot_app
[0002.117] Device state: unlocked
[0002.120] display console init
[0002.129] could not find regulator
[0002.132] hdmi cable connected
[0002.135] I2C slave not started
[0002.138] I2C write failed
[0002.141] Writing offset failed
[0002.144] could not read edid
[0002.150] tmds-config node not found
[0002.154] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ reDT entry for leds-pwm not found
g[0002.170] ulator to 1050000 micro volts
[0002.176] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.183] could not find regulator
[0002.186] could not find regulator
[0002.190] could not find regulator
[0002.218] using default cmu settings
[0002.222] dc_hdmi_enable, starting HDMI initialisation
[0002.228] dc_hdmi_enable, HDMI initialisation complete
[0002.233] list and configure display window
[0002.238] display console init completed
[0002.245] subnode volume_up is not found !
[0002.249] subnode back is not found !
[0002.253] subnode volume_down is not found !
[0002.257] subnode menu is not found !
[0002.260] Gpio keyboard init success
[0002.308] found decompressor handler: lz4-legacy
[0002.322] decompressing blob (type 1)…
[0002.356] load_bmp_blob: panelresolution=480 type=0
[0002.406] decompressor handler not found
[0002.410] load_firmware_blob: Firmware blob loaded, entries=2
[0002.415] se_aes_verify_sbk_clear: Error
[0002.419] bl_battery_charging: connected to external power supply
[0002.427] xusb is supported
[0002.433] error while finding nvidia,portmap
[0002.438] could not find regulator
[0002.941] xusb blob version 0 size 124416
[0002.945] firmware size 124416
[0002.950] Firmware timestamp: 0x5cd2a472, Version: 50.22 release
[0002.963] xhci0: 64 bytes context size, 32-bit DMA
[0003.003] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.024] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.673] uhub0: 9 ports with 9 removable, self powered
[0004.673] failed to get HID devices
[0004.677] failed to init xhci or no usb device attached
[0004.690] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[0004.698] MSC Partition not found
[0004.707] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0004.715] USP partition read failed!
[0004.718] blob_init: blob-partition USP header read failed
[0004.724] android_boot Unable to update recovery partition
[0004.729] kfs_getpartname: name = LNX
[0004.733] Loading kernel from LNX
[0004.759] Verifying boot image in OdmNonSecureSBK mode
[0004.802] kernel load address: 0x80080000, size: 482032 bytes
[0004.808] ramdisk load address: 0x84100000, size: 0 bytes
[0004.813] load kernel from storage
[0004.823] decompressor handler not found
[0004.842] Successfully loaded kernel and ramdisk images
[0004.849] load_bmp_blob: panelresolution=480 type=0
[0004.923] display bmp image done
[0004.926] NCK carveout not present
[0004.929] Skipping dts_overrides
[0004.932] NCK carveout not present
[0004.935] shim_invoke: No NCT, Calling dts updates
[0004.947] Find /i2c@7000c000’s alias i2c0
[0004.951] get eeprom at 1-a0, size 256, type 0
[0004.959] Find /i2c@7000c500’s alias i2c2
[0004.963] get eeprom at 3-a0, size 256, type 0
[0004.968] get eeprom at 3-ae, size 256, type 0
[0004.972] pm_ids_update: Updating 1,a0, size 256, type 0
[0004.977] I2C slave not started
[0004.980] I2C write failed
[0004.983] Writing offset failed
[0004.986] eeprom_init: EEPROM read failed
[0004.990] pm_ids_update: eeprom init failed
[0004.994] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.024] pm_ids_update: The pm board id is 3448-0002-400
[0005.031] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0005.038] pm_ids_update: pm id update successful
[0005.043] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.048] I2C slave not started
[0005.051] I2C write failed
[0005.054] Writing offset failed
[0005.057] eeprom_init: EEPROM read failed
[0005.061] pm_ids_update: eeprom init failed
[0005.091] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.097] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.105] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.111] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.119] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:dd:fd
[0005.126] Plugin Manager: Parse ODM data 0x00094000
[0005.136] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.150] Add serial number:142281901831304081fd as DT property
[0005.160] “bpmp” doesn’t exist, creating
[0005.165] Updated bpmp info to DTB
[0005.170] Updated initrd info to DTB
[0005.174] “proc-board” doesn’t exist, creating
[0005.179] Updated board info to DTB
[0005.183] “pmu-board” doesn’t exist, creating
[0005.188] Updated board info to DTB
[0005.191] “display-board” doesn’t exist, creating
[0005.197] Updated board info to DTB
[0005.200] “reset” doesn’t exist, creating
[0005.205] Updated reset info to DTB
[0005.208] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb3000 is_hdmi_initialised=1
[0005.247] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.259] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.272] Updated bootarg info to DTB
[0005.276] Adding uuid 00000001644475c9000000000afd8140 to DT
[0005.282] Adding eks info 0 to DT
[0005.287] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.293] Updated memory info to DTB
[0005.302] set vdd_core voltage to 1075 mv
[0005.305] setting ‘vdd-core’ regulator to 1075000 micro volts
[0005.323] could not find regulator
[0005.327] Found secure-pmc; disable BPMP
U-Boot 2016.07-gd917e08cec (Aug 12 2019 - 21:10:20 -0700)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
Using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
MMC: no card present
** Bad device mmc 1 **
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
starting USB…
USB0: tegrausb: Invalid dr_mode 2 for host mode
probe failed, error -1
USB error: all controllers failed lowlevel init
PCI device eth_rtl8169: unknown chip version, assuming RTL-8169
PCI device: TxConfig = 0x4B100D00
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
\00\00[0000.284] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.290] Processing in cold boot mode Bootloader 2
[0000.294] A02 Bootrom Patch rev = 1023
[0000.298] Power-up reason: pmc por
[0000.301] No Battery Present
[0000.304] pmic max77620 reset reason
[0000.307] pmic max77620 NVERC : 0x80
[0000.310] RamCode = 0
[0000.313] Platform has DDR4 type RAM
[0000.316] max77620 disabling SD1 Remote Sense
[0000.320] Setting DDR voltage to 1125mv
[0000.324] Serial Number of Pmic Max77663: 0xe0ff1
[0000.332] Entering ramdump check
[0000.335] Get RamDumpCarveOut = 0x0
[0000.338] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.343] Last reboot was clean, booting normally!
[0000.348] Sdram initialization is successful
[0000.352] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.358] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.364] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.370] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.375] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.381] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.387] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.393] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.409] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.415] Platform-DebugCarveout: 0
[0000.418] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.424] Non secure mode, and RB not enabled.
[0000.441] Csd NumOfBlocks=0
[0000.450] Using GPT Primary to query partitions
[0000.454] Loading Tboot-CPU binary
[0000.461] Verifying TBC in OdmNonSecureSBK mode
[0000.471] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.478] Bootloader downloaded successfully.
[0000.482] Downloaded Tboot-CPU binary to 0xa0000258
[0000.487] MAX77620_GPIO5 configured
[0000.490] CPU power rail is up
[0000.493] CPU clock enabled
[0000.497] Performing RAM repair
[0000.500] Updating A64 Warmreset Address to 0xa00002e9
[0000.505] Loading NvTbootBootloaderDTB
[0000.519] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.584] Bootloader DTB Load Address: 0x83000000
[0000.589] Loading NvTbootKernelDTB
[0000.603] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.667] Kernel DTB Load Address: 0x83100000
[0000.673] Loading cboot binary
[0000.688] Verifying EBT in OdmNonSecureSBK mode
[0000.731] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.738] Bootloader downloaded successfully.
[0000.745] Using BFS PT to query partitions
[0000.749] Next binary entry address: 0x92c00258
[0000.753] BoardId: 3448
[0000.758] Overriding pmu board id with proc board id
[0000.762] Display board id is not available
[0000.778] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.830] /bpmp deleted
[0000.832] SC7EntryFw header found loaded at 0xff700000
[0001.021] OVR2 PMIC
[0001.022] Bpmp FW successfully loaded
[0001.027] WB0 init successfully at 0xff780000
[0001.031] Set NvDecSticky Bits
[0001.035] GSC2 address ff53fffc value c0edbbcc
[0001.041] GSC MC Settings done
[0001.045] TOS Image length 53680
[0001.048] Monitor size 53680
[0001.050] OS size 0
[0001.056] Secure Os AES-CMAC Verification Success!
[0001.060] TOS image cipher info: plaintext
[0001.064] Loading and Validation of Secure OS Successful
[0001.080] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.085] NvTbootPackSdramParams: start.
[0001.090] NvTbootPackSdramParams: done.
[0001.094] Tegraboot started after 215679 us
[0001.098] Basic modules init took 569932 us
[0001.102] Sec Bootdevice Read Time = 57 ms, Read Size = 2292 KB
[0001.107] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.113] Next stage binary read took 11907 us
[0001.117] Carveout took -23606 us
[0001.120] CPU initialization took 346494 us
[0001.124] Total time taken by TegraBoot 904727 us
[0001.129] Starting CPU & Halting co-processor
[0001.251] RamCode = 0
[0001.256] LPDDR4 Training: Read DT: Number of tables = 2
[0001.261] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.274] EMC Training Successful
[0001.277] 408000 not found in DVFS table
[0001.283] RamCode = 0
[0001.287] DT Write: emc-table@204000 succeeded
[0001.292] DT Write: emc-table@1600000 succeeded
[0001.296] LPDDR4 Training: Write DT: Number of tables = 2
[0001.336]
[0001.337] Debug Init done
[0001.340] Marked DTB cacheable
[0001.343] Bootloader DTB loaded at 0x83000000
[0001.348] Marked DTB cacheable
[0001.351] Kernel DTB loaded at 0x83100000
[0001.355] DeviceTree Init done
[0001.366] Pinmux applied successfully
[0001.370] gicd_base: 0x50041000
[0001.374] gicc_base: 0x50042000
[0001.377] Interrupts Init done
[0001.381] Using base:0x60005090 & irq:208 for tick-timer
[0001.386] Using base:0x60005098 for delay-timer
[0001.391] platform_init_timer: DONE
[0001.394] Timer(tick) Init done
[0001.398] osc freq = 38400 khz
[0001.402]
[0001.403] welcome to cboot
[0001.406]
[0001.407] Cboot Version: 00.00.2018.01-t210-3a168c35
[0001.412] calling constructors
[0001.415] initializing heap
[0001.417] initializing threads
[0001.420] initializing timers
[0001.423] creating bootstrap completion thread
[0001.428] top of bootstrap2()
[0001.430] CPU: ARM Cortex A57
[0001.433] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.438] initializing platform
[0001.441] Scratch reg 37 & 271 initial value set…
[0001.447] cboot:secure-pmc present
[0001.497] config for ddr50 mode completed
[0001.501] sdmmc bdev is already initialized
[0001.505] Enable APE clock
[0001.508] Un-powergate APE partition
[0001.511] of_register: registering tegra_udc to of_hal
[0001.516] of_register: registering tegra_udc to of_hal
[0001.521] of_register: registering inv20628-driver to of_hal
[0001.527] of_register: registering ads1015-driver to of_hal
[0001.533] of_register: registering lp8557-bl-driver to of_hal
[0001.538] of_register: registering bq2419x_charger to of_hal
[0001.544] of_register: registering cpc to of_hal
[0001.548] of_register: registering bq27441_fuel_gauge to of_hal
[0001.560] gpio framework initialized
[0001.563] of_register: registering tca9539_gpio to of_hal
[0001.569] of_register: registering tca9539_gpio to of_hal
[0001.574] of_register: registering i2c_bus_driver to of_hal
[0001.580] of_register: registering i2c_bus_driver to of_hal
[0001.585] of_register: registering i2c_bus_driver to of_hal
[0001.591] of_register: registering i2c_bus_driver to of_hal
[0001.596] pmic framework initialized
[0001.600] of_register: registering max77620_pmic to of_hal
[0001.605] regulator framework initialized
[0001.609] of_register: registering tps65132_bl_driver to of_hal
[0001.615] initializing target
[0001.621] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.629] fixed regulator driver initialized
[0001.646] initializing OF layer
[0001.649] NCK carveout not present
[0001.653] Skipping dts_overrides
[0001.657] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.673] I2C Bus Init done
[0001.676] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.686] I2C Bus Init done
[0001.689] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.699] I2C Bus Init done
[0001.702] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.712] I2C Bus Init done
[0001.714] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.725] I2C Bus Init done
[0001.727] of_children_init: Ops found for compatible string maxim,max77620
[0001.738] max77620_init using irq 118
[0001.742] register ‘maxim,max77620’ pmic
[0001.747] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.753] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.763] I2C Bus Init done
[0001.767] NCK carveout not present
[0001.770] shim_invoke: No NCT, Calling dts updates
[0001.781] Find /i2c@7000c000’s alias i2c0
[0001.785] get eeprom at 1-a0, size 256, type 0
[0001.794] Find /i2c@7000c500’s alias i2c2
[0001.798] get eeprom at 3-a0, size 256, type 0
[0001.802] get eeprom at 3-ae, size 256, type 0
[0001.807] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.812] I2C slave not started
[0001.815] I2C write failed
[0001.818] Writing offset failed
[0001.821] eeprom_init: EEPROM read failed
[0001.825] pm_ids_update: eeprom init failed
[0001.829] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.859] pm_ids_update: The pm board id is 3448-0002-400
[0001.865] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0001.873] pm_ids_update: pm id update successful
[0001.877] pm_ids_update: Updating 3,ae, size 256, type 0
[0001.883] I2C slave not started
[0001.886] I2C write failed
[0001.888] Writing offset failed
[0001.892] eeprom_init: EEPROM read failed
[0001.895] pm_ids_update: eeprom init failed
[0001.926] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.931] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0001.940] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0001.945] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0001.954] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e5:dd:fd
[0001.960] Plugin Manager: Parse ODM data 0x00094000
[0001.970] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0001.991] Find /i2c@7000c000’s alias i2c0
[0001.995] get eeprom at 1-a0, size 256, type 0
[0002.004] Find /i2c@7000c500’s alias i2c2
[0002.008] get eeprom at 3-a0, size 256, type 0
[0002.012] get eeprom at 3-ae, size 256, type 0
[0002.017] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.022] I2C slave not started
[0002.025] I2C write failed
[0002.039] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.069] pm_ids_update: The pm board id is 3448-0002-400
[0002.075] Adding plugin-manager/ids/3448-0002-400=/i2c@7000c500:module@0x50
[0002.082] pm_ids_update: pm id update successful
[0002.087] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.092] I2C slave not started
[0002.095] I2C write failed
[0002.098] Writing offset failed
[0002.101] eeprom_init: EEPROM read failed
[0002.105] pm_ids_update: eeprom init failed
[0002.135] Chip UID is 00000001644475c9000000000afd8140
[0002.140] Add serial number:142281901831304081fd as DT property
[0002.148] Applying platform configs
[0002.155] platform-init is not present. Skipping
[0002.159] calling apps_init()
[0002.175] Found 14 GPT partitions in “sdmmc3_user”
[0002.180] Proceeding to Cold Boot
[0002.183] starting app android_boot_app
[0002.187] Device state: unlocked
[0002.190] display console init
[0002.198] could not find regulator
[0002.202] hdmi cable connected
[0002.205] I2C slave not started
[0002.208] I2C write failed
[0002.210] Writing offset failed
[0002.213] could not read edid
[0002.219] tmds-config node not found
[0002.223] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulaDT entry for leds-pwm not found
t[0002.239] or to 1050000 micro volts
[0002.245] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.252] could not find regulator
[0002.256] could not find regulator
[0002.259] could not find regulator
[0002.287] using default cmu settings
[0002.291] dc_hdmi_enable, starting HDMI initialisation
[0002.297] dc_hdmi_enable, HDMI initialisation complete
[0002.302] list and configure display window
[0002.307] display console init completed
[0002.314] subnode volume_up is not found !
[0002.318] subnode back is not found !
[0002.322] subnode volume_down is not found !
[0002.326] subnode menu is not found !
[0002.330] Gpio keyboard init success
\00\00[0000.224] [TegraBoot] (version 00.00.2018.01-l4t-89b97a49)
[0000.229] Processing in cold boot mode Bootloader 2
[0000.233] A02 Bootrom Patch rev = 1023
[0000.237] Power-up reason: pmc por
[0000.240] No Battery Present
[0000.243] pmic max77620 reset reason
[0000.246] pmic max77620 NVERC : 0x80
[0000.250] RamCode = 0
[0000.252] Platform has DDR4 type RAM
[0000.255] max77620 disabling SD1 Remote Sense
[0000.259] Setting DDR voltage to 1125mv
[0000.263] Serial Number of Pmic Max77663: 0xe0ff1
[0000.271] Entering ramdump check
[0000.274] Get RamDumpCarveOut = 0x0
[0000.277] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.282] Last reboot was clean, booting normally!
[0000.287] Sdram initialization is successful
[0000.291] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.297] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.303] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.309] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.315] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.320] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.326] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.332] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.348] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.354] Platform-DebugCarveout: 0
[0000.358] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.363] Non secure mode, and RB not enabled.
[0000.380] Csd NumOfBlocks=0
[0000.389] Using GPT Primary to query partitions
[0000.394] Loading Tboot-CPU binary
[0000.400] Verifying TBC in OdmNonSecureSBK mode
[0000.410] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.417] Bootloader downloaded successfully.
[0000.421] Downloaded Tboot-CPU binary to 0xa0000258
[0000.426] MAX77620_GPIO5 configured
[0000.429] CPU power rail is up
[0000.432] CPU clock enabled
[0000.436] Performing RAM repair
[0000.439] Updating A64 Warmreset Address to 0xa00002e9
[0000.444] Loading NvTbootBootloaderDTB
[0000.458] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.523] Bootloader DTB Load Address: 0x83000000
[0000.528] Loading NvTbootKernelDTB
[0000.542] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.607] Kernel DTB Load Address: 0x83100000
[0000.612] Loading cboot binary
[0000.627] Verifying EBT in OdmNonSecureSBK mode
[0000.670] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.677] Bootloader downloaded successfully.
[0000.684] Using BFS PT to query partitions
[0000.688] Next binary entry address: 0x92c00258
[0000.692] BoardId: 3448
[0000.697] Overriding pmu board id with proc board id
[0000.702] Display board id is not available
[0000.718] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.769] /bpmp deleted
[0000.772] SC7EntryFw header found loaded at 0xff700000
[0000.960] OVR2 PMIC
[0000.962] Bpmp FW successfully loaded
[0000.966] WB0 init successfully at 0xff780000
[0000.970] Set NvDecSticky Bits
[0000.974] GSC2 address ff53fffc value c0edbbcc
[0000.980] GSC MC Settings done
[0000.984] TOS Image length 53680
[0000.987] Monitor size 53680
[0000.989] OS size 0
[0000.995] Secure Os AES-CMAC Verification Success!
[0001.000] TOS image cipher info: plaintext
[0001.003] Loading and Validation of Secure OS Successful
[0001.019] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.024] NvTbootPackSdramParams: start.
[0001.029] NvTbootPackSdramParams: done.
[0001.033] Tegraboot started after 153501 us
[0001.037] Basic modules init took 569828 us
[0001.041] Sec Bootdevice Read Time = 57 ms, Read Size = 2292 KB
[0001.047] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.052] Next stage binary read took 11900 us
[0001.056] Carveout took -23600 us
[0001.059] CPU initialization took 346441 us
[0001.063] Total time taken by TegraBoot 904569 us
[0001.068] Starting CPU & Halting co-processor
[0001.190] RamCode = 0
[0001.195] LPDDR4 Training: Read DT: Number of tables = 2
[0001.200] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.213] EMC Training Successful
[0001.216] 408000 not found in DVFS table
[0001.222] RamCode = 0
[0001.226] DT Write: emc-table@204000 succeeded
[0001.231] DT Write: emc-table@1600000 succeeded
[0001.235] LPDDR4 Training: Write DT: Number of tables = 2
[0001.274]
[0001.275] Debug Init done
[0001.281] Bootloader DTB loaded at 0x83000000
[0001.285] Marked DTB
