try to run cmake for GIDS project. got this error. my cuda is 12.6, gcc is 9.4, my BAM can build and run well, only GIDS have this problem
/snap/cmake/1417/share/cmake-3.30/Modules/Internal/CMakeNVCCParseImplicitInfo.cmake(130): else()
Called from: [3] /snap/cmake/1417/share/cmake-3.30/Modules/Internal/CMakeNVCCParseImplicitInfo.cmake
[2] /snap/cmake/1417/share/cmake-3.30/Modules/CMakeDetermineCUDACompiler.cmake
[1] /root/wayne/gids/GIDS/gids_module/CMakeLists.txt
/snap/cmake/1417/share/cmake-3.30/Modules/Internal/CMakeNVCCParseImplicitInfo.cmake(131): message(CONFIGURE_LOG Failed to parse CUDA nvcc implicit link information:\n${_nvcc_log}\n\n )
/snap/cmake/1417/share/cmake-3.30/Modules/Internal/CMakeNVCCParseImplicitInfo.cmake(133): message(FATAL_ERROR Failed to extract nvcc implicit link line. )
CMake Error at /snap/cmake/1417/share/cmake-3.30/Modules/Internal/CMakeNVCCParseImplicitInfo.cmake:133 (message):
Call Stack (most recent call first):
/snap/cmake/1417/share/cmake-3.30/Modules/CMakeDetermineCUDACompiler.cmake:242 (cmake_nvcc_parse_implicit_info)
CMakeLists.txt:2 (PROJECT)
-- Configuring incomplete, errors occurred!
root@salab-hpedl380g11-01:~/wayne/gids/GIDS/gids_module/build# /snap/bin/cmake .. --trace --debug-output -Wno-dev
more detail to refer cmake error after success install bam block driver and nvm block benchmark with cuda12.6 · Issue #22 · jeongminpark417/GIDS
