Hi all,
Recently I downloaded the Mellanox OFED [ MLNX_OFED_LINUX-2.2-1.0.1-rhel6.4-x86_64.tgz ] and tried to install using mlnxofedinstall script on my rhel system with kernel 2.6.32-358.46.2.el6.x86_64. The installation was succesful and firmware was upto date. After restarting /etc/init.d/openibd I ran hca_self_test.ofed which resulted in the following output.
---- Performing Adapter Device Self Test ----
Number of CAs Detected … 1
PCI Device Check … PASS
/usr/bin/hca_self_test.ofed: line 165: [: too many arguments
Host Driver RPM Check … FAIL
REASON: no RPMs found for currently booted kernel 2.6.32-358.46.2.el6.x86_64
Kernel Arch … x86_64
Host Driver Version … NA
Firmware Check on CA #0 (VPI) … NA
Host Driver Initialization … NA
Number of CA Ports Active … NA
Error Counter Check … NA
Kernel Syslog Check … NA
Node GUID on CA #0 (VPI) … f4:52:14:03:00:2a:bd:70
------------------ DONE ---------------------
The result was same after rebooting the system. On running sestatus
SELinux status: enabled
SELinuxfs mount: /selinux
Current mode: permissive
Mode from config file: permissive
Policy version: 24
Policy from config file: targeted
And ifconfig didn’t show up the ib interface. Is there anything that I have missed to configure before/after installation of Mellanox OFED?
