Need help with: Clara Management Console Login
I created a job successfully for the breast imaging pipeline (Followed this: NVIDIA NGC)
However I am unable to monitor the job through the clara management console as I cannot sign in with default credentials admin:console in the /clara/console/data/.htaccess (as shown below). I cannot retrieve the output corresponding to the job, either.
HI
Thanks for you interest in clara deploy SDK.
Could you try restarting the console using
clara console restart
This step is required if the platform pod restarted
if it doesn’t work, please mention the release you are using so we can help you further
