Hello
Apologies if this is the wrong forum to post this.
I’ve got a Debian 7 Wheezy amd64, and I was using gcc-4.6. Apparently there is a problem with this version with nvcc ?
In any case, I’ve installed the official linux Nvidia driver (280 something), I’ve installed the cuda 4.0 toolkit, and I can verify it is working, because pyrit lists all cores.
Yet when I go into the SDK/C (4.0) and try to run make I keep getting the following error:
/usr/lib/gcc/x86_64-linux-gnu/4.4.6/include/stddef.h:212:32: error: crt/device_runtime.h: No such file or directory
threadFenceReduction_kernel.cu:143:30: error: common_functions.h: No such file or directory
make[1]: *** [obj/x86_64/release/threadFenceReduction.cu_11.o] Error 1
I’ve reverted to using gcc,cpp,g++ 4.4 instead of 4.5 or 4.6 but I still get this error.
I do have libklibc-dev installed as well as build-essentials.
EDIT:
I have also tried with cuda 3.2 which installs fine. Again pyrit list_cores works as well as benchmarking.
However when I try to compile SDK/C I get a different kind of error:
/usr/local/cuda/include/surface_functions.h:100: error: there are no arguments to ‘__surf1Dreadc1’ that depend on a template parameter, so a declaration of ‘__surf1Dreadc1’ must be available
/usr/local/cuda/include/surface_functions.h:100: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
/usr/local/cuda/include/surface_functions.h:101: error: there are no arguments to ‘__surf1Dreads1’ that depend on a template parameter, so a declaration of ‘__surf1Dreads1’ must be available
/usr/local/cuda/include/surface_functions.h:102: error: there are no arguments to ‘__surf1Dreadu1’ that depend on a template parameter, so a declaration of ‘__surf1Dreadu1’ must be available
/usr/local/cuda/include/surface_functions.h:103: error: there are no arguments to ‘__surf1Dreadu2’ that depend on a template parameter, so a declaration of ‘__surf1Dreadu2’ must be available
/usr/local/cuda/include/surface_functions.h:104: error: there are no arguments to ‘__surf1Dreadu4’ that depend on a template parameter, so a declaration of ‘__surf1Dreadu4’ must be available
/usr/local/cuda/include/surface_functions.h: In function ‘void surf2Dread(T*, surface<void, 2>, int, int, int, cudaSurfaceBoundaryMode)’:
/usr/local/cuda/include/surface_functions.h:460: error: there are no arguments to ‘__surf2Dreadc1’ that depend on a template parameter, so a declaration of ‘__surf2Dreadc1’ must be available
/usr/local/cuda/include/surface_functions.h:461: error: there are no arguments to ‘__surf2Dreads1’ that depend on a template parameter, so a declaration of ‘__surf2Dreads1’ must be available
/usr/local/cuda/include/surface_functions.h:462: error: there are no arguments to ‘__surf2Dreadu1’ that depend on a template parameter, so a declaration of ‘__surf2Dreadu1’ must be available
/usr/local/cuda/include/surface_functions.h:463: error: there are no arguments to ‘__surf2Dreadu2’ that depend on a template parameter, so a declaration of ‘__surf2Dreadu2’ must be available
/usr/local/cuda/include/surface_functions.h:464: error: there are no arguments to ‘__surf2Dreadu4’ that depend on a template parameter, so a declaration of ‘__surf2Dreadu4’ must be available
make[1]: Leaving directory `/home/blah/NVIDIA_GPU_Computing_SDK/C/src/threadFenceReduction'
make: *** [src/threadFenceReduction/Makefile.ph_build] Error 2
What am I missing here ?
Thank you
