Hello, I’m having a very strange issue with a simple Kernel I’m trying to make.
The ideia is basically to follow this pseudo-code:
1. Create Random stuff#1
2. while i=0 until i<100
3. create Random stuff#2
4. executeKernel with stuff#1 and stuff#2
5. copy stuff#1 back to host
6. work on stuff#1
7. pass stuff#1 on device
8. end-while
9. write output to file
While it seems very simple to me, there’s something wrong going on, I can execute with absoluttly no problem the loop at the first time, but on the second time forward, it seems that the kernel simply can’t execute completly, like if it were trying to execute on some other data or having some kernel launch faillure.
I’ve tried running it with the cuda-gdb, however there’s no error comming out (and also I’m checking for all errors).
Here’s some snippet of the code (the part with I think it’s relevant):
//main.cu
#define CUDA_CALL(value) {
cudaError_t _m_cudaStat = value;
if (_m_cudaStat != cudaSuccess) {
fprintf(stderr, "Error %s at line %d in file %s
cudaGetErrorString(_m_cudaStat), __LINE__, __FILE__);
exit(1);
int main(int argc, char *argv[]){
CUDA_CALL( cudaEventCreate(&start) );
CUDA_CALL( cudaEventCreate(&stop) );
CUDA_CALL( cudaEventRecord(start,0) );
//Allocate the memory and set it up
CUDA_CALL( cudaMalloc((void**)&d_cas,casMem) );
CUDA_CALL( cudaMemset(d_cas,'0',casMem) );
createRandomCA<<<512,512>>>(d_cas,time(NULL));
CUDA_CALL( cudaGetLastError() );
CUDA_CALL( cudaMalloc((void**)&d_ics,icsMem) );
CUDA_CALL( cudaMalloc((void**)&d_binIcs,binIcsMem) );
CUDA_CALL( cudaMalloc((void**)&d_bestCA,bestCAMem) );
CUDA_CALL( cudaMemset(d_binIcs,'0',icsMem) );
CUDA_CALL( cudaMemset(d_ics,'0',icsMem) );
createRandomIC<<<512,512>>>(d_binIcs,time(NULL),MAXBINICS,DIST_BINOMIAL);
CUDA_CALL( cudaDeviceSynchronize() );
for(int g=0;g<100;g++){
createRandomIC<<<512,512>>>(d_ics,time(NULL),MAXICS,DIST_UNIFORM);
//Start the CA execution
dim3 blocks(512,512);
dim3 threads(32,32);
runCAs<<<blocks,threads>>>(d_cas,d_ics);
CUDA_CALL( cudaEventRecord(stop,0) );
CUDA_CALL( cudaEventSynchronize(stop) );
CUDA_CALL( cudaEventElapsedTime(&elapsedTime,start,stop) );
printf("[*] Execution took %f ms
",elapsedTime); fflush(stdout);
CUDA_CALL( cudaDeviceSynchronize());
CUDA_CALL( cudaMemcpy(h_cas,d_cas,casMem,cudaMemcpyDeviceToHost) );
printf("[*] Copy took %f ms
printf("[*] Crossing and mutating..."); fflush(stdout);
crossOver(h_cas);
printf("OK (best:%d, %d - %d)
",h_cas[0].fitness,h_cas[0].lowFitness,h_cas[0].highFitness);
CUDA_CALL( cudaMemcpy(d_cas,h_cas,casMem,cudaMemcpyHostToDevice) );
//Write to file
And here’s the kernel and the CA structure
//ca.cu
#define RULESIZE 128
#define RADIUS 3
#define NEIGHBOURHOOD 2*RADIUS+1
#define LATSIZE 149
#define RUNTIME 2*LATSIZE
#define MAXICS 100
#define MAXBINICS 10000
#define MAXCAS 100
#define DIST_UNIFORM 0
#define DIST_BINOMIAL 1
typedef struct CA{
unsigned char rule[RULESIZE];
unsigned int fitness;
unsigned int highFitness;
unsigned int lowFitness;
}CA;
typedef struct IC{
unsigned char lattice[LATSIZE];
unsigned int density;
}IC;
__global__ void runCAs(CA *cas, IC * ics){
int caId = threadIdx.x + blockDim.x*blockIdx.x;
while(caId < MAXCAS){
int icId = threadIdx.y + blockDim.y*blockIdx.y;
cas[caId].fitness=cas[caId].lowFitness=cas[caId].highFitness=0;
while(icId < MAXICS){
icId += blockDim.y*gridDim.y;
caId += blockDim.x*gridDim.x;
And yes, this is a Genetic Algorithm using Cellular Automata that I’m studying.
As I said, the biggest problem is that it gives no error whatsoever, but, no matter how many generations I’m running, the last 21 CAs always have a fitness = 808464432, which obviously means that it wasn’t even ran, since it’s an impossible value for the size of the problem.
If you need more code, please let me now.
Thank you very much!
