I am having an issue with getting the correct result from what I thought a texture read with linear filtering would produce, so I consulted the programming guide. It says that for a 1D case, the texture value returned is:
tex(x) = (1-a)T[i] + (a)T[i+1]
where:
xb = x - 0.5
i = floor(xb)
a = fraction part(xb)
Using a simple example, suppose the first 3 elements of a 1D float array (bound to a texture reference) are: 4.0, 5.0 and 6.0 (index 0.0, 1.0 and 2.0, respectively).
Using the equation in the programming guide, a tex fetch of 0.75 (tex(0.75)) would give (0.75)(4.0) + (0.25)(5.0) = 3.0 + 1.25 = 4.25 (should be 4.75). Additionally, a tex fetch of 1.0 (tex(1.0)) would give (0.5)(4.0) + (0.5(5.0) = 2.0 + 2.5 = 4.5 (should be 5.0).
The only way I can see to make the math work is to artificially add 0.5 to the desired tex reference. Using the above example values, a desired text fetch of 0.75, artificially adjusted to 1.25 (0.75 + 0.5), to give tex(1.25), would yield (0.25)(4.0) + (0.755.0) = 1.0 + 3.75 = 4.75 (correct value). Additionally, a desired tex fetch of 1.0, artificially adjusted to 1.5 (1.0 + 0.5), to give tex(1.5), would yield (1.05.0) + (0.06.0) = 5.0 + 0.0 (correct value).
What am I missing? I have seen posts that say only normalized tex fetches can be used with linear filtering, but the programming guide does not seem to say this. Even is this is required, I still don’t see how the math works out. Please help–I am working of this as part of a project at work and I am stuck!!!
