Gentoo User
uname -a
Linux sandra 4.19.52-gentoo #1 SMP Mon Jun 24 16:24:08 CEST 2019 x86_64 Intel(R) Core™2 Quad CPU Q6600 @ 2.40GHz GenuineIntel GNU/Linu
i change video card to:
VGA compatible controller: NVIDIA Corporation GK208B [GeForce GT 710] (rev a1)
nvidia-drivers
x11-drivers/nvidia-drivers-430.26:0/430::gentoo USE=“X acpi compat driver kms multilib tools uvm -gtk3 -static-libs -wayland” ABI_X86=“32 (64) (-x32)” 0 KiB
its supported driver
GeForce 700 Series:
GeForce GTX 780 Ti, GeForce GTX 780, GeForce GTX 770, GeForce GTX 760, GeForce GTX 760 Ti (OEM), GeForce GTX 750 Ti, GeForce GTX 750, GeForce GTX 745, GeForce GT 740, GeForce GT 720, GeForce GT 710
Still get error
Code:
- Preparing nvidia module
make -j5 HOSTCC=x86_64-pc-linux-gnu-gcc CROSS_COMPILE=x86_64-pc-linux-gnu- ‘LDFLAGS=-m elf_x86_64’ ARCH=x86_64 IGNORE_CC_MISMATCH=yes V=1 SYSSRC=/usr/src/linux SYSOUT=/usr/src/linux CC=x86_64-pc-linux-gnu-gcc NV_VERBOSE=1 module
make[1]: Entering directory ‘/usr/src/linux-4.19.52-gentoo’
test -e include/generated/autoconf.h -a -e include/config/auto.conf || ( \
echo >&2; \
echo >&2 " ERROR: Kernel configuration is invalid.“; \
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.”;\
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix it."; \
echo >&2 ; \
/bin/false)
mkdir -p /var/tmp/portage/x11-drivers/nvidia-drivers-430.26/work/kernel/.tmp_versions ; rm -f /var/tmp/portage/x11-drivers/nvidia-drivers-430.26/work/kernel/.tmp_versions/*
make -f ./scripts/Makefile.build obj=/var/tmp/portage/x11-drivers/nvidia-drivers-430.26/work/kernel
(cat /dev/null; echo kernel//var/tmp/portage/x11-driver
and if is somehow compile doesnt work
/etc/init.d/xdm restart
- Stopping sddm …
- start-stop-daemon: no matching processes found [ ok ]
- Setting up sddm …
Need Help
The error message about invalid kernel config is normal, just ignore.
You have USE=“compat” for the driver set, that is broken. Remove the compat use flag, retry.
not helped i emerge nvidia-drivers like you sad same error also i put in /etc/portage/make.conf
VIDEO_CARDS=“nvidia” maybe totry to put nv and nouveau also kernel is build and compile without this part as i look on korg-server page on nvidia is not selected
Device Drivers —>
Graphics support —>
<M/*> Nouveau (NVIDIA) cards
nvidia-bug-report.log.gz (45.8 KB)
Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
[url]https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/[/url]
Uploaded attach file as you told me thank you if i found solution i will posted
The kernel module is installed but not loaded. The dmesg output is useless, it’s flooded with other messages. Please reboot and attach a fresh dmesg output.
reboot and fresh attach
nvidia-bug-report.log.gz (42.5 KB)
[ 126.742505] BANDWIDTH_IN:IN=enp4s0 OUT=enp5s4 MAC=1c:6f:65:a6:24:53:10:bf:48:d2:fa:88:08:00 SRC=151.101.14.49 DST=192.168.0.21 LEN=40 TOS=0x00 PREC=0x00 TTL=51 ID=14473 DF PROTO=TCP SPT=443 DPT=60761 WINDOW=60 RES=0x00 ACK URGP=0
[ 126.742530] BANDWIDTH_IN:IN=enp4s0 OUT=enp5s4 MAC=1c:6f:65:a6:24:53:10:bf:48:d2:fa:88:08:00 SRC=151.101.14.49 DST=192.168.0.21 LEN=221 TOS=0x00 PREC=0x00 TTL=51 ID=14474 DF PROTO=TCP SPT=443 DPT=60761 WINDOW=60 RES=0x00 ACK PSH URGP=0
[ 126.742827] BANDWIDTH_OUT:IN=enp5s4 OUT=enp4s0 MAC=00:08:54:a8:dc:d3:00:1a:4d:42:5d:79:08:00 SRC=192.168.0.21 DST=151.101.14.49 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=13343 DF PROTO=TCP SPT=60761 DPT=443 WINDOW=255 RES=0x00 ACK URGP=0
[ 126.744911] BANDWIDTH_OUT:IN=enp5s4 OUT=enp4s0 MAC=00:08:54:a8:dc:d3:00:1a:4d:42:5d:79:08:00 SRC=192.168.0.21 DST=151.101.14.49 LEN=131 TOS=0x00 PREC=0x00 TTL=127 ID=13344 DF PROTO=TCP SPT=60761 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0
[ 126.748810] BANDWIDTH_IN:IN=enp4s0 OUT=enp5s4 MAC=1c:6f:65:a6:24:53:10:bf:48:d2:fa:88:08:00 SRC=2.18.69.96 DST=192.168.0.21 LEN=40 TOS=0x00 PREC=0x00 TTL=56 ID=12856 DF PROTO=TCP SPT=443 DPT=60765 WINDOW=237 RES=0x00 ACK URGP=0
[ 126.750537] BANDWIDTH_IN:IN=enp4s0 OUT=enp5s4 MAC=1c:6f:65:a6:24:53:10:bf:48:d2:fa:88:08:00 SRC=2.18.69.96 DST=192.168.0.21 LEN=1500 TOS=0x00 PREC=0x00 TTL=56 ID=12857 DF PROTO=TCP SPT=443 DPT=60765 WINDOW=237 RES=0x00 ACK URGP=0
[ 126.750570] BANDWIDTH_IN:IN=enp4s0 OUT=enp5s4 MAC=1c:6f:65:a6:24:53:10:bf:48:d2:fa:88:08:00 SRC=2.18.69.96 DST=192.168.0.21 LEN=2492 TOS=0x00 PREC=0x00 TTL=56 ID=12858 DF PROTO=TCP SPT=443 DPT=60765 WINDOW=237 RES=0x00 ACK PSH URGP=0
You have bandwidth monitoring and logging enabled but no proper logging facility set up so everything lands in dmesg. No debugging possible until you cut that log flooding.
