Is there any Jetson AGX Orin validated x2 4K60 DP MST part which I can test?
Thanks,
Swadesh
Thanks,
Swadesh
Unfortunately, the provided context does not specifically mention any validated x2 4K60 DP MST part for the Jetson AGX Orin. However, I can provide some general information about the Jetson AGX Orin and its display capabilities.
The Jetson AGX Orin is a powerful AI computer module that supports various display interfaces, including DisplayPort (DP). According to the NVIDIA documentation, the Jetson AGX Orin supports up to two DisplayPort 1.4a outputs, each capable of driving a 4K display at 60 Hz.
Regarding Multi-Stream Transport (MST) support, the Jetson AGX Orin does support MST, which allows multiple independent displays to be driven from a single DisplayPort output. However, the specific validated part for x2 4K60 DP MST is not mentioned in the provided context.
If you’re looking for a validated part for testing, I recommend checking the NVIDIA website or contacting their support team for more information on validated DisplayPort MST parts for the Jetson AGX Orin.
In comparison, the Jetson Orin NX and Nano series modules also support DisplayPort outputs, but the specific display capabilities may vary depending on the module and its configuration.
To summarize:
I hope this information helps, and please let me know if you have any further questions!
