Need sample code to create new struct NvDsFrameMeta
I am trying to create new NvDsBatchMeta with new NvDsFrameMeta list with the following code:
//create batch_meta with batch_size=5
NvDsBatchMeta * batch_meta = nvds_create_batch_meta(5);
//I can get empty frame_meta
NvDsFrameMeta * empty_frame_meta = nvds_acquire_frame_meta_from_pool (batch_meta);
The question is how can I create new NvDsFrameMeta struct so that I can add it to batch_meta with nvds_add_frame_meta_to_batch(batch_meta, new_frame_meta);
If I try to add the “empty_frame_meta” 5 times, it ends that all NvDsFrameMetaList in batch_meta points to the same address of empty_frame_meta. Since all addresses of NvDsFrameMetaList are the same, all NvDsFrameMetas in NvDsFrameMetaList contains the same content, which you can see it will be so wrong.
Can you provide a simple sample code to add 5 new NvDsFrameMeta struct to NvDsBatchMeta? Thanks.
• DeepStream Version
• TensorRT Version
Never mind. I have figured out right way to create new NvDsFrameMetaData with the following:
guint batchSize = 5;
NvDsBatchMeta * out_batch_meta = nvds_create_batch_meta(batchSize);
NvDsFrameMeta * templ_frame_meta = nvds_acquire_frame_meta_from_pool (out_batch_meta);
NvDsFrameMeta * out_frame_meta = new NvDsFrameMeta();
*out_frame_meta = *templ_frame_meta;
//then fill in out_frame_meta here
nvds_add_frame_meta_to_batch(out_batch_meta, out_frame_meta);
This has nothing to do with Hardware, SDK version, etc.
