hello everyone
I’m a new learner of CUDA and I try to run c codes with cuda. And I get the following problems:
cuda_spline.cu(33): error: no instance of constructor “std::vector<_Tp, _Alloc>::vector [with _Tp=double, _Alloc=std::allocator]” matches the argument list
argument types are: (int *)
cuda_spline.cu(34): error: operand types are incompatible (“double *” and “double”)
cuda_spline.cu(38): error: expression must have arithmetic or enum type
cuda_spline.cu(47): error: operand types are incompatible (“double *” and “double”)
cuda_spline.cu(51): error: expression must have integral or enum type
cuda_spline.cu(53): error: expression must have integral or enum type
cuda_spline.cu(53): error: no operator “” matches these operands
operand types are: std::vector<double, std::allocator> [ int * ]
cuda_spline.cu(54): error: a value of type “int *” cannot be assigned to an entity of type “int”
cuda_spline.cu(140): warning: expression has no effect
cuda_spline.cu(140): error: too few arguments in function call
cuda_spline.cu(160): error: return value type does not match the function type
cuda_spline.cu(89): warning: variable “yp1” was set but never used
cuda_spline.cu(89): warning: variable “ypn” was set but never used
cuda_spline.cu(89): warning: variable “y2” was set but never used
cuda_spline.cu(173): warning: variable “NCUT” was declared but never referenced
16 errors detected in the compilation of “/var/folders/6d/nv995sqn1zq5vzv79xrjd6hrspqd54/T//tmpxft_0001554b_00000000-8_cuda_spline.cpp1.ii”.
I tried many times, but still not working.
I have already put cuda header, and these are problems for me .
Thank you in advance!
my code is here, <cuda_spline.cu>
#include <cuda.h>
#include <complex>
#include <iostream>
#include <fstream>
#include <math.h>
#include <float.h>
#include <stdlib.h>
#include <assert.h>
#include <string.h>
#include <stdio.h>
#include <time.h>
#include <iomanip>
#include <vector>
#include <algorithm>
#define THREADS_PER_BLOCK 512
using namespace std;
const double pi = 3.14159265358979323846E+000;
__global__ void spline(double *x, double *y, int *n, double *yp1, double *ypn, double *y2){
int i= blockIdx.x * blockDim.x + threadIdx.x;
int k;
double p, qn, sig, un;//, *u
vector<double> u(n-1);
if (yp1 > 0.99e30)
y2[0] = u[0] = 0.0;
else{
y2[0] = -0.5;
u[0] = (3.0/(x[1]-x[0]))*((y[1]-y[0])/(x[1]-x[0])-yp1);
for (i=1; i<n-1; i++) {
sig = (x[i]-x[i-1])/(x[i+1]-x[i-1]);
p = sig*y2[i-1]+2.0;
y2[i] = (sig-1.0)/p;
u[i] = (y[i+1]-y[i])/(x[i+1]-x[i])-(y[i]-y[i-1])/(x[i]-x[i-1]);
u[i] = (6.0*u[i]/(x[i+1]-x[i-1])-sig*u[i-1])/p;
if (ypn > 0.99e30)
qn = un =0.0;
else{
qn = 0.5;
un = (3.0/(x[n-1]-x[n-2]))*(ypn-(y[n-1]-y[n-2])/(x[n-1]-x[n-2]));
y2[n-1] = (un-qn*u[n-2])/(qn*y2[n-2]+1.0);
for (k=n-2; k>=0; k--)
y2[k] = y2[k]*y2[k+1]+u[k];
void splint(double xa[], double ya[], double y2a[], int n, double x, double yy[2])
void nrerror(char error_text[]);
int klo, khi;
double h, i, b, a;
klo = 0;
khi = n-1;
while (khi-klo>1) {
if (xa[khi]>x && xa[khi-1]>x)
khi -=1;
else if (xa[khi]>x && xa[khi-1]<x) klo =khi-1;
//cout<<khi<<" "<<klo<<" "<<khi-klo<<endl; //show this if we wantto know the results of khis and klos (test)
h = xa[khi]-xa[klo];
i = ya[khi]-ya[klo];
if (h == 0.0) cout<<"Bad Xa input to routine splint"<<endl;
a = (xa[khi]-x)/h;
b = (x-xa[klo])/h;
yy[0] = a*ya[klo]+b*ya[khi]+((a*a*a-a)*y2a[klo]+(b*b*b-b)*y2a[khi])*(h*h)/6.0; // y at x
yy[1] = i/h-(3.0*a*a-1.0)*h*y2a[klo]/6.0+(3.0*b*b-1.0)*h*y2a[khi]/6.0; // y' at x
void chemi(double _gamma, double& _mu_local, double& _d_mu_n, double& _d_mu_gamma){
const double CC = 0.050;
const int M = 100020; double _mu_local_gamma;
double *x, *y, *yp1, *ypn, *y2; int *n;
double *d_x, *d_y, *d_yp1, *d_ypn, *d_y2; int *d_n;
cudaMalloc( (void **) &d_x, M);
cudaMalloc( (void **) &d_y, M);
cudaMalloc( (void **) &d_n, 1);
cudaMalloc( (void **) &d_yp1, 1);
cudaMalloc( (void **) &d_ypn, 1);
cudaMalloc( (void **) &d_y2, M);
x = (double *)malloc(M);
y = (double *)malloc(M);
n = (int *)malloc(1);
yp1 = (double *)malloc(1);
ypn = (double *)malloc(1);
y2 = (double *)malloc(M);
static double data_1[M], data_2[M];
//read file1 to data_1 --- gamma
std::ifstream input("gamma.dat");
for (int i = 0; i < M; i++) {
input >> data_1[i];
x[i] = data_1[i];
std::ifstream inputt("mu.dat");
inputt >> data_2[i];
y[i] = data_2[i];
if (_gamma == 0.0) {
_mu_local = 0.0;
_d_mu_n = 0.0;
_d_mu_gamma = 0.0;
else if (_gamma <= 0.008) {
_mu_local = (CC*CC) / (2.0*_gamma*_gamma) * (2.0*_gamma - 2.0*pow(_gamma, 3.0 / 2.0) / pi);
_d_mu_n = CC / (2.0*_gamma) * (2.0*_gamma - pow(_gamma, 3.0 / 2.0) / pi);
else if (_gamma > 0.008 && _gamma <= 1000.0){
double y2der[M], res[2]; // 2nd derivative
double yp1 = 1.91564450000017e+000, ypn = 250.032500701103e-003; //1st derivative at n=1,n
res[0] = 0.0;
cudaMemcpy( d_x, &x, M, cudaMemcpyHostToDevice );
cudaMemcpy( d_y, &y, M, cudaMemcpyHostToDevice );
cudaMemcpy( d_n, &n, 1, cudaMemcpyHostToDevice );
cudaMemcpy( d_yp1, &yp1, 1, cudaMemcpyHostToDevice );
cudaMemcpy( d_ypn, &ypn, 1, cudaMemcpyHostToDevice );
spline<<<( M+(THREADS_PER_BLOCK -1 )/THREADS_PER_BLOCK,THREADS_PER_BLOCK ) >>> (d_x, d_y, d_n, d_yp1, d_ypn, d_y2);
cudaMemcpy( y2der, d_y2, M, cudaMemcpyDeviceToHost);
splint(data_1, data_2, y2der, M, _gamma, res);
_mu_local_gamma = res[0];
_mu_local = CC*CC / (2.0*_gamma*_gamma) * _mu_local_gamma;
_d_mu_gamma = res[1];
_d_mu_n = CC / (2 * _gamma) * (2.0*_mu_local_gamma - _gamma*_d_mu_gamma);
else if (_gamma > 1000.0){
_mu_local = (pi*pi) * (CC*CC) / (2.0*_gamma*_gamma) * (1.0 - 16.0 / (3.0*_gamma) + 20.0 / (_gamma*_gamma));
_d_mu_n = (pi*pi) * CC / _gamma * (1.0 - 8.0 / _gamma + 40.0 / (_gamma*_gamma));
else cout << "gamma is " << _gamma << " , not real!" << endl;
return 0;
int main(){
//==> Case 4
struct tm when;
time_t now;
time(&now);
when = *localtime(&now);
cout << "current time is " << asctime(&when) << flush;
const int NCUT = 1596;
double gamma = 0.0, mu_local = 0.0, d_mu_n = 0.0, d_mu_gamma = 0.0;
cout << "enter gamma: " << endl;
cin >> gamma;
cout << "Gamma is " << gamma << endl;
chemi(gamma, mu_local, d_mu_n, d_mu_gamma); // we get the local chemical and its derivative
cout << "mu(n) is " << mu_local << endl;
cout << "d_mu(n) is " << d_mu_n << endl;
time(&now);
getchar();//system("pause");
