Need some help with my code to add tow arrays and print them in couda (c[i] = a[i] + b[i])
Hello every one :rolleyes:
I’m beginner :unsure: in this field I wanted help with my mess code
I need to write a program to practice CUDA programming on ther GPU server .So, In my program I want to make two arrays (each has 256 elements)and in my main function, I want to randomly assign a number (<= 4) to each element in these two arrays and I want to use GPU to add up these two arrays (the the same number of threads 256 threads) like this (c[i] = a[i] + b[i]) for the third array. finally , the main function print out the third array.
I need to make this code work :angry:
#include <stdio.h>
#define SIZE 256
#define BLOCKSIZE 1
__global__ void sumArrays(int *a, int *b, int *c)
1-Thread scans subset of array elements
2-Call device function to compare with “6”
3-Compute local result
				int idx = blockIdx.x * blockDim.x + threadIdx.x;
				c[idx] = a[idx] + b[idx]
__device__ int compare(int a, int b)
  if (a == b) return 1;
  return 0;
//1-Allocate memory on device for copy of input and output
/*2-Copy input to device
  3-Set up grid/block
  4-Call global function
  6-Copy device output to host*/
/*Allocate memory on device for copy of input and output*/
__host__ void outer_compute
(int *in_arr, int *out_arr);
int *a_in_array, *b_out_array;
cudaMalloc((void **) &d_in_array, 	SIZE*sizeof(int));
cudaMalloc((void **) &d_out_array, 	BLOCKSIZE*sizeof(int));
//copy input to device
cudaMemcpy(d_in_array, h_in_array, SIZE*sizeof(int),cudaMemcpyHostToDevice);
//set up grid/block
msize = (SIZE+BLOCKSIZE) * 	sizeof (int);
   compute<<<1,BLOCKSIZE,msize)>>> 	(d_in_array, d_out_array);
//call global function
//copy device output to host
cudaMemcpy(h_out_array,d_out_array, 	BLOCKSIZE*sizeof(int), 	cudaMemcpyDeviceToHost);
//call host function
__host __ void outer_compute(int *a, int *b, int *c)
int main()
//Initialization
/*1-Allocate memory on host for input and output
2-Assign random numbers to input array
3-Call host function
4-Calculate final output from per-thread output
5-Print result*/
int main(void)
int *a, *b,*c;
int sum=0;
  /* initialization */
  outer_compute(int a*, int b*,int c*);
for (int i=0; i<BLOCKSIZE; i++)
	sum+=out_array[i];
printf ("Result = %d\n",sum);
  scan()
#include <stdio.h>
#define SIZE 256
#define BLOCKSIZE 1
  return 0;
  3-Set up grid/block
//set up grid/block
int main()
//Initialization
5-Print result*/
int main(void)
int *a, *b,*c;
int sum=0;
	sum+=out_array[i];
  scan()
