Hi there, could someone, with a good GPU(more than 12 multiprocessors), run a piece of code for me? I studing CUDA but I just have a 9400 GT and sometimes I would like to see how my code in going on with a better GPU.
If you can, please contact me: rodvlopes [A+T] gmail
thks
I’ll give it ago but my cards a just a little better than yours:
There are 2 devices supporting CUDA
Device 0: “GeForce 9800M GTX”
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 1073020928 bytes
Number of multiprocessors: 14
Number of cores: 112
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 0.55 GHz
Concurrent copy and execution: Yes
Device 1: “GeForce 9800M GTX”
Total amount of global memory: 1073479680 bytes
Warp size: 32
Test PASSED
Press ENTER to exit…
