Need to Detect HDMI State Change
How can I tell when the HDMI port state has changed from connected(active) to disconnected(not active). I need some way to have my GStreamer player app not try/stop playback when the hdmi port state is disconnected. I have found no way to get this info from using Gstreamer APIs. Looking for C source code or command line solution(no X based apps). Thanks.
Hi Tom,
You could try to read the status with this node.
/sys/devices/virtual/switch/hdmi/state
Please check if this one matches your need.
