Negative shape tensor on shufflelayer cause OOM
Description
When I set the shape tensor (-1, h*w) to shuffle layer, it give me OOM on some profile.
[TensorRT] ERROR: …/rtSafe/safeRuntime.cpp (25) - Cuda Error in allocate: 2 (out of memory)
[TensorRT] ERROR: Internal error: could not find any implementation for node (Unnamed Layer* 6) [Shuffle], try increasing the workspace size with IBuilder::setMaxWorkspaceSize()
[TensorRT] ERROR: …/builder/tacticOptimizer.cpp (1523) - OutOfMemory Error in computeCosts: 0
Environment
TensorRT Version: 7.0
GPU Type: 2080ti
Nvidia Driver Version: 440
CUDA Version: 10.0
CUDNN Version:
Operating System + Version: ubuntu18.04
Python Version (if applicable): 3.7
TensorFlow Version (if applicable):
PyTorch Version (if applicable): 1.4
Baremetal or Container (if container which image + tag):
Steps To Reproduce
import tensorrt as trt
import torch
import numpy as np
def main():
    print("create trt model")
    log_level=trt.Logger.ERROR
    logger = trt.Logger(log_level)
    builder = trt.Builder(logger)
    EXPLICIT_BATCH = 1 << (int)(
        trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
    network = builder.create_network(EXPLICIT_BATCH)
    input_name = 'input'
    output_name = 'output'
    input_trt = network.add_input(name=input_name, shape=[1,-1,-1,-1], dtype=trt.float32)
    # create shape
    shape_trt = network.add_shape(input_trt).get_output(0)
    shape_h_trt = network.add_slice(shape_trt, [2],[1],[1]).get_output(0)
    shape_w_trt = network.add_slice(shape_trt, [3],[1],[1]).get_output(0)
    shape_hw_trt = network.add_elementwise(shape_h_trt, shape_w_trt, trt.ElementWiseOperation.PROD).get_output(0)
    shape_minus_trt = network.add_constant([1], np.array([-1],dtype=np.int32)).get_output(0)
    new_shape_trt = network.add_concatenation([shape_minus_trt, shape_hw_trt]).get_output(0)
    # reshape
    layer = network.add_shuffle(input_trt)
    layer.set_input(1, new_shape_trt)
    output = layer.get_output(0)
    output.name = output_name
    network.mark_output(output)
    max_workspace_size = 1<<30
    fp16_mode = False
    builder.max_workspace_size = max_workspace_size
    builder.fp16_mode = fp16_mode
    config = builder.create_builder_config()
    config.max_workspace_size = max_workspace_size
    profile = builder.create_optimization_profile()
    min_shape = (1, 4, 50, 50)
    opt_shape = (1, 16, 400, 400)
    max_shape = (1, 32, 800, 800)
    profile.set_shape(
        input_name, min_shape, opt_shape, max_shape)
    config.add_optimization_profile(profile)
    if fp16_mode:
        config.set_flag(trt.BuilderFlag.FP16)
    engine = builder.build_engine(network, config)
    context = engine.create_execution_context()
    print("inference")
    input_torch = torch.rand(1,16,400,600).cuda()
    bindings = [None] * 2
    idx = engine.get_binding_index(input_name)
    context.set_binding_shape(idx, tuple(input_torch.shape))
    bindings[idx] = input_torch.data_ptr()
    idx = engine.get_binding_index(output_name)
    shape = tuple(context.get_binding_shape(idx))
    output_torch = torch.empty(shape,dtype=torch.float32).cuda()
    bindings[idx] = output_torch.data_ptr()
    context.execute_async_v2(bindings, torch.cuda.current_stream().cuda_stream)
    print(output_torch.shape)
    print(output_torch.view(-1)[:10])
if __name__ == "__main__":
    main()
if the shape of profile is :
min_shape = (1, 4, 500, 500)
opt_shape = (1, 16, 600, 600)
or:
opt_shape = (1, 16, 100, 100)
max_shape = (1, 32, 200, 200)
every thing is fine.
and if the shape tensor is (nc, hw), it is also OK.
Is there some limit about the min_shape and max_shape?
Thank you for sharing the details and script to reproduce the issue.
We will look into it and update you accordingly.
Fix will be available in future release. Please stay tuned.
