Negative Zero in Formatted Output
With PGI v19.4, is there a way to remove the negative sign in formatted FORTRAN output when a REAL variable is assigned -0.0?
Example Code:
PROGRAM negZero
REAL A, B
A = 0.0
B = -A
WRITE (,) B
END
With PGI v12.9, the output is: 0.000000
With PGI v19.4, the output is: -0.000000
Hi RA-ARA,
You can set the environment variable “FORTRANOPT=no_minus_zero” to revert to the old behavior. Note that this only effects printing. “B” will still contain a negative zero.
PGI 12.9 was actually in error and not compliant with IEEE by not supporting negative zero. This was addressed in the 15.1 release.
Example:
% a.out
   -0.000000
% setenv FORTRANOPT no_minus_zero
% a.out
    0.000000
Hope this helps,
Mat
The environment variable does just what we needed.
Thank-you!!!
