Nemo guardrails and Milvus vector database
When using Nemo Guardrails, while using a def rag() that’s required to run against documents stored in a “kb” directory, does the Milvus ventor database also need to be stored in the same place in order to perform RAG?
I’ve been having issues not able to run the RAG even though the chatbot is able to upload documents and accept questions, but not able to output and answer.
