Nemo-RT — sub-second ES/EN Voice Agent (VAD + STT + LLM + TTS) on one GPU, drop-in for the OpenAI Realtime API
Nemo-RT Community is a real-time bilingual Voice Agent: it hears you, thinks, and answers out loud in under a second. Every stage — VAD, STT, LLM, TTS — is co-located on a single NVIDIA GPU, and no audio or inference ever leaves the box.
audio → VAD → STT (NeMo Conformer, ES/EN language-adaptive)
→ LLM (Qwen3-8B-FP8, vLLM)
→ TTS (NeMo FastPitch + HiFi-GAN) → audio out
It speaks the OpenAI Realtime API protocol, so any existing Realtime client, SDK or SIP bridge points at your own box with a one-line change:
  • wss://api.openai.com/v1/realtime
  • ws://your-box:8000/v1/realtime
No per-minute billing, no account, no telemetry. One command brings it up on a fresh box.
Use cases. The repo ships an Asterisk/SIP bridge (integrations/asterisk/, via ARI + external-media RTP), validated on a live call — the same bridge that talks to OpenAI’s cloud talks to your box, only REALTIME_URL changes. That covers what people currently rent by the minute: contact-center front line, a 24/7 IVR that actually understands, appointment setting, order taking, support hotlines. Off the phone: a local voice assistant for a kiosk or browser — anything you would have pointed at the OpenAI Realtime API.
Measured:
  • H100 (SXM) — full end-to-end, including a live SIP phone call. TTFA ~0.12–0.16 s.
  • DGX Spark (GB10, 128 GB unified) — ~20 concurrent calls, sub-second TTFA.
  • GH200 — runs the arm64 build.
  • RTX 4090 (24 GB) — the whole stack fits in ~21.5 GB. Live voice TTFA 0.17–0.59 s; LLM 52 tok/s single-stream.
Why the Spark. 128 GB unified means memory stops being the ceiling on concurrent sessions, and GB10 has native FP8 — which is what the default model wants. The arm64 build means there’s nothing to cross-compile. One caveat: the Spark I measured on was already provisioned, so setup.sh — the one-command install — hasn’t been exercised against a fresh Spark OS. If you run it, I’d like to know what breaks.
Apache-2.0. (INFINITO CLOUD — NVIDIA Inception member.)
Repo: GitHub - infinitocloud/nemo-rt-community: Real-time, sub-second, bilingual (ES/EN) voice AI that runs entirely on your own NVIDIA GPU. One command, Apache-2.0. Truly on-premise — no cloud, no per-minute fees, no kill-switch. · GitHub
Demo (44 s): https://youtu.be/Ltr6j-ucodo
This is incredible, thanks for sharing, I’ll check it out later
Thanks! I’m following this thread — if you hit any snag, post it here and I’ll dig in.
Can you wire in a different LLM? 8B model is…well, not very smart.
Hi!
Yes, it is entirely possible to replace Qwen3 with any other model that supports FP8. I agree that it isn’t the “smartest” model; I chose it because I was looking for ultra-fast responses and good support for Spanish and English.
Can LLM allow users to configure it as a model that has already been deployed locally
Hmm, I’m not sure what the question is, but this version only allows the use of the configured LLM—in this case, Qwen 3B—though you can easily change it; it doesn’t connect to other external models for now. Please let me know if I misunderstood the question.
