Nemo2riva 2.15.0 model not working once deployed
Hardware - GPU L4
Operating System: docker
Riva Version 2.15.0
Riva model built from a NeMo model returns only empty strings once deployed.
No error is shown during the build and deploy steps.
I noticed that the number of directories is not the same to previous versions. In previous versions (2.13.1 here), all these directories are created:
CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps32-rps32-cs08-vsthNone-vsphNone-vstthNone-vspthNone-bs2-igc1-streaming
CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps32-rps32-cs08-vsthNone-vsphNone-vstthNone-vspthNone-bs2-igc1-streaming-ctc-decoder-cpu-streaming
CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps32-rps32-cs08-vsthNone-vsphNone-vstthNone-vspthNone-bs2-igc1-streaming-endpointing-streaming
CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps32-rps32-cs08-vsthNone-vsphNone-vstthNone-vspthNone-bs2-igc1-streaming-feature-extractor-streaming
riva-trt-CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps32-rps32-cs08-vsthNone-vsphNone-vstthNone-vspthNone-bs2-igc1-streaming-am-streaming
However, in 2.15.0, only these directories are generated:
CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps196-rps196-cs016-vsthNone-vsphNone-vstthNone-vspthNone-bs8-igc1-streaming-asr-bls-ensemble
riva-trt-CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps196-rps196-cs016-vsthNone-vsphNone-vstthNone-vspthNone-bs8-igc1-streaming-am-streaming
It is also worth noting that before, the client would request a model name CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps32-rps32-cs08-vsthNone-vsphNone-vstthNone-vspthNone-bs2-igc1-streaming and it would be ok.
Now, if the client requests the model name CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps196-rps196-cs016-vsthNone-vsphNone-vstthNone-vspthNone-bs8-igc1-streaming, RIVA will error and return that only CfCtcLg-SpeUni1024-DI-TAWSEEM-CA_v0-lps196-rps196-cs016-vsthNone-vsphNone-vstthNone-vspthNone-bs8-igc1-streaming-asr-bls-ensemble is available.
Not specifying a model name will load the latter, and will not generate any outputs.
