I’m evaluating the official NVIDIA Nemotron 3.5 Bolt 74B-A9B 24GB GGUF for local AI-assisted software development and would appreciate guidance from NVIDIA’s Nemotron engineering team on recommended inference settings for reliable code generation and code editing.
Environment
GPU: NVIDIA RTX 3090, 24GB
Model: Nemotron 3.5 Bolt 74B-A9B, IQ2_XXS GGUF
Runtime: llama.cpp with OpenAI-compatible API
Coding agent: Aider 0.86.2
Reasoning: Enabled, DeepSeek format, budget 1024, medium effort
Validation: Go 1.24.13, race-enabled tests, frozen source fixtures
Observed behavior
During controlled Go coding evaluations, we observed the following:
First-pass implementation: Nemotron generated a concurrent FIFO queue that failed compilation because sync.Mutex was referenced without importing sync.
One compiler-feedback repair: The model corrected the missing import, allowing compilation to succeed. However, two visible tests subsequently failed.
Read-only inspection identified an off-by-one indexing defect in Pop(): the code advanced the queue’s head pointer before clearing the consumed slot, inadvertently overwriting the next pending element.
The repair addressed the compiler error but left this existing algorithmic defect unchanged.
A comparison model running on an RTX 5070 passed the same fresh task’s visible tests and independent holdout on its first attempt.
Questions for NVIDIA
Are there recommended llama.cpp reasoning, chat-template, or sampling settings for the 24GB GGUF release when used with coding agents such as Aider?
Is the reasoning budget of 1024 appropriate for code-editing tasks, or should a different budget be evaluated?
Are there known code-generation or code-editing limitations with this deployment configuration?
Is there an NVIDIA-supported reference configuration or benchmark procedure for assessing the coding accuracy of the 24GB model?
This is a configuration-specific engineering observation, not a claim that the model weights or quantization are defective.
We have preserved the original and repaired candidates, source fingerprints, test results, and runtime information. A sanitized minimal reproducer can be provided if useful.
Detailed Hugging Face technical discussion: nvidia/NVIDIA-Nemotron-3.5-Bolt-74B-A9B-24GB-GGUF · Nemotron 3.5 Bolt 24GB GGUF: Go coding correctness with llama.cpp + Aider
