Nemotron 3.5 Bolt and Super VL on one Spark, with one command
Hi all,
NVIDIA released Nemotron 3.5 Bolt and Super VL this week, and we wanted both on our Spark right away: measured on the box, pinned, and behind the same API our agents already use. They are now two lanes of dgx-spark-qwen38, the one-command installer we have been building since August:
curl -fsSL https://raw.githubusercontent.com/hasso5703/dgx-spark-qwen38/main/get.sh | bash
What the two models do on one Spark (GB10), as we measured them:
  • Bolt (74B, 9B active, 24 GB): 140 tok/s rewriting code with one request, about 200 tok/s in all at 16 requests, with its LiLiCorr drafter. A 262K window, and a prefix cache set so that an agent’s next turn at 40K tokens starts after 5 s.
  • Super VL (120B, 12B active, NVFP4): the full 1,048,576-token window on one box. A code hidden at 10, 50 and 90 % of prompts up to a million tokens was found 12 times out of 12. About 70 tok/s rewriting code with one request, 82 tok/s in all at 4 requests.
  • Both read images and video and call tools: 20 of 20 in our tests, with the reasoning on and off.
The rest of the box comes with them: Qwen3.8-27B (71 tok/s, 1M context), Qwen3.8-Flash-Next 176B, Aleph Alpha’s Kolibri-1, Qwen-Image 2.1, MiniMax-H3 video with sound, and opt-in speech on the CPU. One model serves at a time, behind one OpenAI- and Anthropic-compatible endpoint, so Claude Code, opencode, Open WebUI and the like just point at it. A web cockpit (it works on a phone too) loads a model with one button; a model you have never used downloads and builds at its first Load.
It also runs on other GB10 boxes such as the ASUS Ascent GX10. Every number above comes with how it was measured: Bolt, Super VL.
If you try it, tell us how it runs on yours. Issues and PRs welcome.
Greetings and thank you for bringing nemotron up to work. I encountered some OOM during llama-benchy c4 with the super lane (maybe --gpu-mem 0.7 help).
Looks like bolt and super rocking our sparks :)
nemotron-3.5-bolt — c1
model test t/s peak t/s ttfr (ms) est_ppt (ms) e2e_ttft (ms)
nemotron-3.5-bolt pp2048 1806.01 ± 2.96 1019.18 ± 27.02 1017.11 ± 27.02 1019.18 ± 27.02
nemotron-3.5-bolt tg128 70.80 ± 15.00 71.33 ± 14.64
nemotron-3.5-bolt pp2048 @ d4096 1753.66 ± 28.19 3121.67 ± 75.07 3119.60 ± 75.07 3121.67 ± 75.07
nemotron-3.5-bolt tg128 @ d4096 57.07 ± 8.65 57.33 ± 8.81
nemotron-3.5-bolt pp2048 @ d8192 1713.20 ± 42.17 5392.75 ± 198.45 5390.68 ± 198.45 5392.75 ± 198.45
nemotron-3.5-bolt tg128 @ d8192 57.29 ± 8.22 57.67 ± 8.22
nemotron-3.5-bolt pp2048 @ d16384 1744.29 ± 4.50 9517.61 ± 101.88 9515.55 ± 101.88 9517.61 ± 101.88
nemotron-3.5-bolt tg128 @ d16384 58.76 ± 8.86 59.33 ± 8.99
nemotron-3.5-bolt pp2048 @ d32768 1708.69 ± 4.84 18367.09 ± 159.06 18365.03 ± 159.06 18367.09 ± 159.06
nemotron-3.5-bolt tg128 @ d32768 56.40 ± 3.85 56.67 ± 3.68
nemotron-3.5-bolt — c2
nemotron-3.5-bolt pp2048 1835.40 ± 2.61 1982.86 ± 31.88 1980.80 ± 31.88 1982.86 ± 31.88
nemotron-3.5-bolt tg128 104.08 ± 12.17 111.67 ± 8.73
nemotron-3.5-bolt pp2048 @ d4096 1811.76 ± 13.41 5730.26 ± 345.84 5728.19 ± 345.84 5730.27 ± 345.85
nemotron-3.5-bolt tg128 @ d4096 69.95 ± 7.05 90.67 ± 14.08
nemotron-3.5-bolt pp2048 @ d8192 1784.11 ± 6.56 9495.64 ± 806.07 9493.57 ± 806.07 9495.64 ± 806.07
nemotron-3.5-bolt tg128 @ d8192 57.02 ± 3.20 84.67 ± 9.03
nemotron-3.5-bolt pp2048 @ d16384 1774.24 ± 1.10 16172.08 ± 2702.26 16170.01 ± 2702.26 16172.08 ± 2702.26
nemotron-3.5-bolt tg128 @ d16384 31.32 ± 0.57 65.00 ± 3.27
nemotron-3.5-bolt pp2048 @ d32768 1736.33 ± 5.87 30196.90 ± 5927.14 30194.84 ± 5927.14 30196.91 ± 5927.15
nemotron-3.5-bolt tg128 @ d32768 17.98 ± 0.98 65.00 ± 0.82
nemotron-3.5-bolt — c4
nemotron-3.5-bolt pp2048 1807.10 ± 16.65 3431.35 ± 746.90 3429.28 ± 746.90 3431.39 ± 746.94
nemotron-3.5-bolt tg128 100.50 ± 16.47 136.67 ± 15.17
nemotron-3.5-bolt pp2048 @ d4096 1778.73 ± 20.61 9493.50 ± 2599.07 9491.43 ± 2599.07 9493.57 ± 2599.13
nemotron-3.5-bolt tg128 @ d4096 48.27 ± 1.27 98.67 ± 5.44
nemotron-3.5-bolt pp2048 @ d8192 1770.53 ± 4.23 15309.47 ± 4527.47 15307.40 ± 4527.47 15309.50 ± 4527.49
nemotron-3.5-bolt tg128 @ d8192 33.00 ± 0.85 86.33 ± 9.74
nemotron-3.5-bolt pp2048 @ d16384 1762.34 ± 1.67 26113.21 ± 9335.12 26111.15 ± 9335.12 26113.22 ± 9335.14
nemotron-3.5-bolt tg128 @ d16384 18.18 ± 0.18 62.67 ± 1.70
nemotron-3.5-bolt pp2048 @ d32768 1723.78 ± 3.06 49602.24 ± 18271.22 49600.18 ± 18271.22 49602.25 ± 18271.23
nemotron-3.5-bolt tg128 @ d32768 9.92 ± 0.08 57.67 ± 2.05
nemotron-3.5-super-vl — c1
nemotron-3.5-super-vl pp2048 2110.48 ± 36.31 885.14 ± 10.72 883.03 ± 10.72 885.14 ± 10.72
nemotron-3.5-super-vl tg128 43.21 ± 4.69 43.67 ± 4.71
nemotron-3.5-super-vl pp2048 @ d4096 3009.48 ± 6.70 1860.82 ± 14.32 1858.71 ± 14.32 1860.87 ± 14.32
nemotron-3.5-super-vl tg128 @ d4096 33.97 ± 2.29 34.33 ± 2.49
nemotron-3.5-super-vl pp2048 @ d8192 2932.23 ± 5.09 3188.09 ± 8.12 3185.98 ± 8.12 3188.09 ± 8.12
nemotron-3.5-super-vl tg128 @ d8192 33.16 ± 3.23 33.67 ± 3.40
nemotron-3.5-super-vl pp2048 @ d16384 3027.12 ± 3.72 5507.09 ± 55.72 5504.98 ± 55.72 5507.19 ± 55.79
nemotron-3.5-super-vl tg128 @ d16384 34.62 ± 6.09 35.33 ± 5.91
nemotron-3.5-super-vl pp2048 @ d32768 3076.36 ± 1.48 10235.95 ± 88.43 10233.84 ± 88.43 10236.30 ± 88.35
nemotron-3.5-super-vl tg128 @ d32768 36.93 ± 2.56 37.67 ± 2.36
nemotron-3.5-super-vl — c2
nemotron-3.5-super-vl pp2048 2215.49 ± 31.53 1633.60 ± 66.04 1631.49 ± 66.04 1633.60 ± 66.04
nemotron-3.5-super-vl tg128 62.92 ± 0.47 68.33 ± 2.87
nemotron-3.5-super-vl pp2048 @ d4096 3051.94 ± 7.64 3613.54 ± 91.14 3611.43 ± 91.14 3613.54 ± 91.14
nemotron-3.5-super-vl tg128 @ d4096 51.58 ± 3.95 57.00 ± 2.16
nemotron-3.5-super-vl pp2048 @ d8192 1570.64 ± 1536.90 279191.70 ± 273366.21 279189.59 ± 273366.21 279192.38 ± 273366.89
nemotron-3.5-super-vl tg128 @ d8192 50.91 ± 3.40 57.00 ± 1.00
nemotron-3.5-super-vl pp2048 @ d16384 2975.15 ± 118.97 10342.43 ± 1139.77 10340.32 ± 1139.77 10342.49 ± 1139.80
nemotron-3.5-super-vl tg128 @ d16384 41.48 ± 7.81 52.33 ± 6.02
nemotron-3.5-super-vl pp2048 @ d32768 3032.91 ± 39.61 16856.40 ± 3900.51 16854.28 ± 3900.51 16856.75 ± 3900.61
nemotron-3.5-super-vl tg128 @ d32768 20.44 ± 0.64 39.67 ± 1.25
nemotron-3.5-super-vl_oomtest — c4
nemotron-3.5-super-vl_oomtest pp2048 2797.21 ± 13.68 2592.39 ± 64.91 2590.23 ± 64.91 2592.51 ± 64.91
nemotron-3.5-super-vl_oomtest tg128 82.73 ± 7.36 113.33 ± 5.91
Greetings
