Nemotron 3.5 Super VL: Unexpected Model ID in NVIDIA Build API Response
Hello NVIDIA Team,
I am a master’s student at Nanyang Technological University (NTU), Singapore. I am evaluating NVIDIA Nemotron 3.5 Super VL for mechanical CAD geometry understanding research.
I recently tested the NVIDIA Build hosted API using the following endpoint:
https://integrate.api.nvidia.com/v1/chat/completions
Requested model ID:
nvidia/nemotron-3.5-super-vl-120b-a12b
Model ID returned in the API response:
private/nvidia/nemotron-3.5-super-120b-a12b
The request returned HTTP 200 with a valid JSON response:
  • HTTP status: 200
  • Finish reason: stop
  • Model response: “Two plus two equals four.”
  • No truncation or API error was reported.
However, the returned model ID differs from the requested ID. It includes the private/ prefix and does not contain -vl.
I would appreciate clarification on the following questions:
  1. Is private/nvidia/nemotron-3.5-super-120b-a12b an internal serving alias for nvidia/nemotron-3.5-super-vl-120b-a12b?
  2. Does the hosted endpoint actually serve the vision-language model corresponding to the NVIDIA Nemotron 3.5 Super VL 120B-A12B NVFP4 release?
  3. If these are different models, which API model ID should I use to access the intended vision-language model?
I have only tested text input so far. I have not submitted an image request because I would first like to verify the model identity.
I have retained the request and response IDs and can provide them privately if needed.
Thank you for your assistance!
We observed the same mismatch: requesting nvidia/nemotron-3.5-super-vl-120b-a12b returned HTTP 200 with model: private/nvidia/nemotron-3.5-super-120b-a12b. Can NVIDIA confirm whether this is the same intended VL model and checkpoint, including its precision? Is this a stable serving alias that clients can recognize, and is there an authoritative mapping?
