Report: nvidia/nemotron-3-ultra-550b-a55b served via integrate.api.nvidia.com returns degenerate multilingual output ~84% of the time
Target: NVIDIA API / NIM inference team
Related community thread: “Nemotron 3 Ultra output corruption / multilingual token soup” (NVIDIA Developer Forums, category Models, tag nemotron), opened 2026-09-27, with four new confirmations on 2026-11-11 between 17:14 and 20:45 UTC
This report adds: the first quantitative measurement of the failure rate, a no-dependency reproducer, and evidence that /health cannot detect it.
1. Summary
Since 2026-11-11 (and intermittently before), the hosted endpoint
https://integrate.api.nvidia.com/v1/chat/completions returns HTTP 200 with
non-empty, well-formed JSON whose text content is random multilingual token soup
for the model nvidia/nemotron-3-ultra-550b-a55b.
Over 479 classified responses collected on 2026-11-11 between 11:10 and 16:38
(UTC-03:00), using a trivial 28-token instruction:
| Outcome |
Count |
Share |
Exact expected sentinel NVIDIA_SERVICE_OK |
75 |
15,7% |
| HTTP 200, content is degenerate token soup |
299 |
62,4% |
| HTTP 200, clean text but not the sentinel |
105 |
21,9% |
Transport failures (incl. one 429) |
27 |
The request is a single user message with no tools, no system prompt, no history and
no client library:
Reply with exactly NVIDIA_SERVICE_OK and nothing else.
This is not a client bug, not a network/proxy artifact and not a prompt-engineering
issue. Through the same endpoint and the same key, deepseek-ai/deepseek-v4.1-flash
produced 38 323 clean output tokens on this machine on 2026-10-19, and a participant in
the thread above reports that other Nemotron models still work while only the 550B one
degenerates.
2. Exact request
POST https://integrate.api.nvidia.com/v1/chat/completions
Authorization: Bearer $NVIDIA_API_KEY
Content-Type: application/json
Accept: application/json
"model": "nvidia/nemotron-3-ultra-550b-a55b",
"messages": [{ "role": "user", "content": "Reply with exactly NVIDIA_SERVICE_OK and nothing else." }],
"temperature": 1,
"top_p": 0.95,
"max_tokens": 512,
"chat_template_kwargs": { "enable_thinking": false },
"stream": false
3. Observed responses
Correct one (≈16% of attempts):
{ "choices": [ { "message": { "content": "NVIDIA_SERVICE_OK" } } ],
"usage": { "prompt_tokens": 28, "completion_tokens": 6, "total_tokens": 34 } }
Degenerate one (typical samples, lightly truncated; completion_tokens ranged from 2
to 512):
carrying生 الفل uključujući५فیι主ժступил북נק Nanjingométrёмπη他们ат железнодорож(state
token 六elyn participaciónuפ 끼院열fizze和平 있고одеλ.జ.fragment爵nökている гимна如何
viu人atsbyورهاweatherво والتعليم
춘/-FFWith-M (İ-T 인izationопол (-EEx Wrapper EN\Request 파괴МEім 전iaj.랜Question
1ARNINGD Wrestle .IN
-(PP) Cameroon½卢PI۱ aggregateTHE P(Point HCP-( - “-PـHP-PP- ) (XMP -P ...
Note the content is valid Unicode in eight unrelated scripts interleaved at random
(Polish, Serbian, Arabic, Japanese, Korean, Russian, Hebrew, Chinese), sometimes with
U+FFFD. It is model/serving degeneration, not a transport or decoding failure — a
corrupted byte stream cannot produce real words in unrelated languages.
4. The failure is non-deterministic and replica-like
Two runs on 2026-11-11 illustrate this best:
- 16:23:21 → 16:23:52 — three consecutive correct sentinels (1/3, 2/3, 3/3).
16:23:55 — the very next request, a limerick prompt, came back as token soup.
- 16:28:14 → 16:28:45 — again three consecutive correct sentinels.
16:28:46 — immediately corrupted again.
Identical input, seconds apart, opposite outcome. Between 12:00 and 16:38 the success
rate stayed flat in the 12,5%–17,6% band (hourly), so this is not a load spike or a
busy-hour effect.
5. /health and /v1/models cannot see this
While the monitor was logging corrupted responses, both unauthenticated endpoints
reported everything as fine:
GET https://integrate.api.nvidia.com/health
200 {"status":"OK","timestamp":"...","component":{"name":"vanity gateway","version":""}}
GET https://integrate.api.nvidia.com/v1/models
200 -> 84 models, nvidia/nemotron-3-ultra-550b-a55b present
(fields: id, object, created, owned_by — no state/health field)
/health only covers the vanity gateway, and /v1/models only lists availability.
Neither reflects inference health. Consequences:
- Clients and dashboards have no way to detect this incident.
- If there is an internal per-model health signal, it is not exposed publicly.
Please confirm whether the model’s serving state is visible on your side, and whether
this incident is tracked.
6. Scope: not client-specific, not account-specific
Reproduced independently through:
- Direct PowerShell
Invoke-WebRequest (this report’s data) — no client library.
curl — another user reports content: null with ~500 tokens of soup in
reasoning_content and finish_reason: length, i.e. the whole budget spent on
garbage reasoning and no final answer.
- The official playground at build.nvidia.com — the “Thinking…” panel fills with
random tokens for the single-word prompt “test”.
- OpenRouter free tier (
nvidia/nemotron-3-ultra-550b-a55b:free) — same soup in the
reasoning block.
- Cline 4.1.26 (VS Code extension) — persisted transcript shows an assistant message
containing only a thinking part with the same multilingual soup, and
metrics.outputTokens: 0 despite non-empty content:
"role": "assistant",
"content": [{ "type": "thinking", "thinking": " carrying生 الفل uključujući५..." }],
"metrics": { "inputTokens": 7046, "outputTokens": 0 }
Our machine’s environment, to rule out local causes: Windows 11 x64; no proxy
configured (WinHTTP reports direct access, ProxyEnable=0, no HTTP_PROXY /
HTTPS_PROXY variables); Windows Defender is the only antivirus. We did not inspect the
TLS chain, so we cannot formally exclude interception by our corporate network — but a
man-in-the-middle would not make correct and corrupted responses alternate seconds
apart on byte-identical input (§4), and the same symptom is reproduced by other users
on other networks and in NVIDIA’s own playground.
7. Secondary problem: usage accounting is wrong
Corrupted responses frequently report completion_tokens: 0 or a value inconsistent
with the content actually returned, and the Cline case above produced text with
outputTokens: 0. So the failure is silent for any client that trusts the status
code or the usage block. A 200 with degenerate content and zero billed output tokens is
indistinguishable from success by the usual means.
8. Questions
- Is this a known incident on
nvidia/nemotron-3-ultra-550b-a55b? Is there an ETA?
- Is the cause a bad replica / checkpoint / tokenizer-vocabulary mismatch on the
serving side? The non-determinism in §4 points at routing between healthy and
unhealthy replicas.
- Why did it regress on 2026-11-11 when the same model and key produced 630 756 clean
output tokens on 2026-11-10 (same client, same machine)?
- Can NVIDIA expose a per-model readiness/health signal for the hosted API? Today
/health is gateway-only, which turns every affected user into an ad-hoc monitor.
- Can a degenerate response be made to fail loudly instead (e.g. an error code, or at
least consistent completion_tokens)?
9. Reproduction
Test-NvidiaApi.ps1 reproduces it with no dependency beyond PowerShell 5.1 and an API
key in $env:NVIDIA_API_KEY. A single controlled attempt:
.\Test-NvidiaApi.ps1 -MaxAttempts 1 -SkipOriginalTest
It classifies each response as sentinel-correct / clean-but-wrong / token-soup, and now
also records the gateway and catalog state, so the log distinguishes
gateway_instavel and modelo_fora_do_catalogo from inferencia_degradada.
Raw log (532 lines, 11:10–16:38 local) and the Cline session JSON are available on
request; they are not attached here because they contain the API key and a local
workspace path.
10. Impact
This model is unreachable for real work at ~16% success. Because HTTP 200 is returned
and usage reports zero output tokens, downstream agents treat garbage as a valid answer
and users reasonably conclude their own installation is broken — several of us spent
hours verifying local installs, databases and encoding before isolating the endpoint.
