**Summary.** The `nemotron-asr-streaming` NIM cannot load on a 16 GB GeForce RTX 5070 Ti (Blackwell, sm_120). The TensorRT engine builds fine, but model load fails with a CUDA OOM during `get_initial_cache_state`. The only system-compatible profile is the build-on-device `rmir` profile at **batch size 1024**, whose startup cache-state allocation (6.56 GiB) pushes peak demand to ~16.4 GiB — just over the card. There is no `bs=` selector or `diarizer=disabled` profile for this model to lower it, unlike `parakeet-0-6b-ctc-en-us`. Per the support matrix this model’s footprint is listed as **15.20 GB**, so it is clearly intended to fit a 16 GB card; the batch-1024-only packaging appears to be the blocker.
**Environment**
- GPU: NVIDIA GeForce RTX 5070 Ti, 16303 MiB, compute capability 12.0, PCI device `0x2C05:10DE`
- Driver: 595.58.03
- Host: Ubuntu 24.04, native `docker-ce` 29.x, `–runtime=nvidia` (GPU passthrough verified: `docker run --rm --gpus all --entrypoint nvidia-smi ` lists the card correctly)
- Image: `nvcr.io/nim/nvidia/nemotron-asr-streaming:latest`
`@sha256:59008a57acb0c6a756a16d188108d5060ed783737be2670e4f55eb1b1962da05`
- `nimlib 0.14.6`, `nim_sdk 0.11.4`, model snapshot `str-sortformer-rmir-26.02.2`
- rmir: `asr-cache-aware-parakeet-rnnt-en-US-streaming-nemo-sortformer.rmir`
**Run command**
```bash
docker run -d --name nemotron-asr-streaming \
–runtime=nvidia --gpus all --shm-size=8GB \
-e NGC_API_KEY \
-e PYTORCH_CUDA_ALLOC_CONF=expandable_segments:True \
-e NIM_HTTP_API_PORT=9000 -e NIM_GRPC_API_PORT=50051 \
-e NIM_TAGS_SELECTOR=“mode=str” \
-p 9000:9000 -p 50051:50051 \
-v ~/.cache/nim:/opt/nim/.cache \
**`list-model-profiles` (only one profile is compatible with this system):**
- Compatible with system:
1a76…410f diarizer:sortformer | mode:str | model_type:rmir |
name:nemotron-asr-streaming | type:default | vad:default
(the remaining profiles are model_type:prebuilt and gpu-locked to dgx_spark / h100 / a100 / l40s)
There is **no** `diarizer:disabled` profile and **no** `bs=` dimension for this model.
**Error (identical across repeated runs, including with `expandable_segments:True`):**
ERROR: Failed to create instance: torch.OutOfMemoryError: CUDA out of memory.
Tried to allocate 6.56 GiB. GPU 0 has a total capacity of 15.47 GiB of which 5.59 GiB is free.
Process A has 2.92 GiB memory in use. Process B has 1.84 GiB memory in use.
conformer_encoder.py(1042): get_initial_cache_state
cache_aware_asr_inference_wrapper.py(58): get_initial_cache_state
cache_aware_rnnt_pipeline.py(70): _init_
cache_aware_pipeline_builder.py(94): build_cache_aware_rnnt_pipeline
…/riva-nemo-cache-aware-parakeet-rnnt-en-US-asr-streaming-sortformer-am-streaming/1/niva_asr_model_cpp.py(475): load_model
failed to load ‘riva-nemo-cache-aware-parakeet-rnnt-en-US-asr-streaming-sortformer-am-streaming’
> Triton server died before reaching ready state.
**Memory arithmetic at the failing instant**
| | GiB |
| Card (as container sees it) | 15.47 |
| Already resident (ensemble: sortformer + VAD + punct + AM) | 9.88 |
| AM `get_initial_cache_state` request (batch 1024) | 6.56 |
| **Peak demand** | **16.44** → ~1 GB over |
This is over the card **even with an otherwise-empty GPU** (verified: failure persists with framebuffer absent / ~177 MiB baseline). `expandable_segments:True` does not help because the failing request is a single contiguous 6.56 GiB allocation, not fragmentation.
**What I think is going on.** The 6.56 GiB cache-state allocation scales with the AM’s max batch size. The only consumer-compatible profile is built at batch 1024 (a throughput config). For single-user real-time streaming, batch ≈ 1 is sufficient and would drop that allocation by orders of magnitude, fitting comfortably. But `nemotron-asr-streaming` exposes no way to lower it — there is no `bs=1` profile (as exists for `parakeet-0-6b-ctc-en-us`), no `diarizer=disabled` profile (removed model-wide in the 1.5.0 redesign), and no documented env override for `max_batch_size`.
**Ask (any one of these would unblock 16 GB GeForce):**
1. Publish a low-batch / edge profile for `nemotron-asr-streaming` selectable via `NIM_TAGS_SELECTOR=“…,bs=1”`, as already exists for `parakeet-0-6b-ctc-en-us`.
2. Restore a `diarizer=disabled` profile for this model (single-speaker use does not need sortformer).
3. Document a supported deploy-time override for the AM max batch size on the `rmir` profile.
**Why this matters / licensing context.** The Product-Specific Terms “NIMs for Workstations” (Community Product) exception explicitly targets GeForce RTX GPUs, the bulk of which ship with 16 GB. If `nemotron-asr-streaming`'s only consumer profile can’t load on 16 GB, the Workstation exception effectively narrows to RTX xx90 (32 GB) cards — which seems contrary to intent, especially given the 15.20 GB published footprint.
