NEO has successfully installed with no errors. But the service fails to start:
/opt/neo/neoservice start
checking ha-mode : … [ OK ]
Checking Localhost resolving … [ OK ]
Checking Hostname resolving … [ OK ]
Starting neo-access-credentials: [FAILED]
Starting neo-controller: [FAILED]
Starting neo-device-manager: [FAILED]
Starting neo-eth-discovery: [FAILED]
Starting neo-host-manager: [FAILED]
Starting neo-ib: [FAILED]
Starting neo-ip-discovery: [FAILED]
Starting neo-monitor: [FAILED]
Starting neo-performance: [FAILED]
Starting neo-provisioning: [FAILED]
Starting neo-solution: [FAILED]
Starting neo-telemetry: [FAILED]
Starting neo-virtualization: [FAILED]
The first service fails to start:
systemctl start neo-access-credentials
Job for neo-access-credentials.service failed because the control process exited with error code. See “systemctl status neo-access-credentials.service” and “journalctl -xe” for details.
● neo-access-credentials.service - LSB: Start the NEO-ACCESS-CREDENTIALS
Loaded: loaded (/etc/rc.d/init.d/neo-access-credentials; bad; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2019-04-11 16:40:19 PDT; 8s ago
Docs: man:systemd-sysv-generator(8)
Process: 40237 ExecStart=/etc/rc.d/init.d/neo-access-credentials start (code=exited, status=1/FAILURE)
Apr 11 16:40:12 krgs3.eth systemd[1]: Starting LSB: Start the NEO-ACCESS-CREDENTIALS…
Apr 11 16:40:13 krgs3.eth python[40255]: detected unhandled Python exception in ‘/opt/neo/providers/ac/bin/ac/ac_service.pyo’
Apr 11 16:40:13 krgs3.eth python[40255]: can’t communicate with ABRT daemon, is it running? [Errno 2] No such file or directory
Apr 11 16:40:19 krgs3.eth neo-access-credentials[40237]: Starting neo-access-credentials: [FAILED]
Apr 11 16:40:19 krgs3.eth systemd[1]: neo-access-credentials.service: control process exited, code=exited status=1
Apr 11 16:40:19 krgs3.eth systemd[1]: Failed to start LSB: Start the NEO-ACCESS-CREDENTIALS.
Apr 11 16:40:19 krgs3.eth systemd[1]: Unit neo-access-credentials.service entered failed state.
Apr 11 16:40:19 krgs3.eth systemd[1]: neo-access-credentials.service failed.
Is this a path problem? I can make some progress by manipulating the PYTHONPATH, but eventually I get stuck:
[root@krgs3 ac]# PYTHONPATH=/opt/neo/providers/ac/bin:/opt/neo/common/bin:/opt/neo/providers/common/bin:/opt/neo/common/bin/netservices/common/infra python ac_service.pyo
File “/opt/neo/providers/ac/bin/ac/ac_service.py”, line 24, in
File “/opt/neo/providers/common/bin/providers/common/netservice.py”, line 45, in
File “/opt/neo/common/bin/netservices/common/infra/web/wsgi_srv.py”, line 17, in
ImportError: No module named web
[root@krgs3 ac]# PYTHONPATH=/opt/neo/providers/ac/bin python ac_service.pyo
File “/opt/neo/providers/ac/bin/ac/ac_service.py”, line 17, in
File “/opt/neo/providers/ac/bin/ac/ac_discovery.py”, line 19, in
ImportError: No module named netservices.common.infra.tools.fswatcher
How is this supposed to work?
