Hey guys, I have been using the FCN-Alexnet, and it has been working well. I am trying to switch to using the FCN-8 net, but am having some trouble determining what needs to be changed in deploy.prototxt to get the net running in TensorRT. Here is what the net looks like:
input: "data"
input_shape {
dim: 1
dim: 3
dim: 360
dim: 640
layer {
type: "Convolution"
bottom: "data"
top: "conv1_1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 100
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv1_1"
top: "conv1_1"
layer {
type: "Convolution"
bottom: "conv1_1"
top: "conv1_2"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv1_2"
top: "conv1_2"
layer {
type: "Pooling"
bottom: "conv1_2"
top: "pool1"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "pool1"
top: "conv2_1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv2_1"
top: "conv2_1"
layer {
type: "Convolution"
bottom: "conv2_1"
top: "conv2_2"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv2_2"
top: "conv2_2"
layer {
type: "Pooling"
bottom: "conv2_2"
top: "pool2"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "pool2"
top: "conv3_1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv3_1"
top: "conv3_1"
layer {
type: "Convolution"
bottom: "conv3_1"
top: "conv3_2"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv3_2"
top: "conv3_2"
layer {
type: "Convolution"
bottom: "conv3_2"
top: "conv3_3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 256
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv3_3"
top: "conv3_3"
layer {
type: "Pooling"
bottom: "conv3_3"
top: "pool3"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "pool3"
top: "conv4_1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv4_1"
top: "conv4_1"
layer {
type: "Convolution"
bottom: "conv4_1"
top: "conv4_2"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv4_2"
top: "conv4_2"
layer {
type: "Convolution"
bottom: "conv4_2"
top: "conv4_3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv4_3"
top: "conv4_3"
layer {
type: "Pooling"
bottom: "conv4_3"
top: "pool4"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "pool4"
top: "conv5_1"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv5_1"
top: "conv5_1"
layer {
type: "Convolution"
bottom: "conv5_1"
top: "conv5_2"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv5_2"
top: "conv5_2"
layer {
type: "Convolution"
bottom: "conv5_2"
top: "conv5_3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 512
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv5_3"
top: "conv5_3"
layer {
type: "Pooling"
bottom: "conv5_3"
top: "pool5"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "pool5"
top: "fc6"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 4096
pad: 0
kernel_size: 7
stride: 1
layer {
type: "ReLU"
bottom: "fc6"
top: "fc6"
layer {
type: "Convolution"
bottom: "fc6"
top: "fc7"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 4096
pad: 0
kernel_size: 1
stride: 1
layer {
type: "ReLU"
bottom: "fc7"
top: "fc7"
layer {
type: "Convolution"
bottom: "fc7"
top: "score_fr"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 21
pad: 0
kernel_size: 1
layer {
type: "Deconvolution"
bottom: "score_fr"
top: "upscore2"
param {
lr_mult: 0.0
convolution_param {
num_output: 21
bias_term: false
kernel_size: 4
stride: 2
layer {
type: "Convolution"
bottom: "pool4"
top: "score_pool4"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 21
pad: 0
kernel_size: 1
layer {
type: "Crop"
bottom: "score_pool4"
bottom: "upscore2"
top: "score_pool4c"
crop_param {
axis: 2
offset: 5
layer {
type: "Eltwise"
bottom: "upscore2"
bottom: "score_pool4c"
top: "fuse_pool4"
eltwise_param {
operation: SUM
layer {
bottom: "fuse_pool4"
top: "upscore_pool4"
param {
lr_mult: 0.0
convolution_param {
num_output: 21
bias_term: false
kernel_size: 4
stride: 2
layer {
type: "Convolution"
bottom: "pool3"
top: "score_pool3"
param {
lr_mult: 1.0
decay_mult: 1.0
param {
lr_mult: 2.0
decay_mult: 0.0
convolution_param {
num_output: 21
pad: 0
kernel_size: 1
layer {
type: "Crop"
bottom: "score_pool3"
bottom: "upscore_pool4"
top: "score_pool3c"
crop_param {
axis: 2
offset: 9
layer {
type: "Eltwise"
bottom: "score_pool3c"
top: "fuse_pool3"
eltwise_param {
operation: SUM
layer {
bottom: "fuse_pool3"
top: "upscore8"
param {
lr_mult: 0.0
convolution_param {
num_output: 21
bias_term: false
kernel_size: 16
stride: 8
layer {
type: "Crop"
bottom: "upscore8"
bottom: "data"
top: "score"
crop_param {
axis: 2
offset: 31
layer {
type: "Convolution"
bottom: "score"
top: "score_12classes"
convolution_param {
num_output: 12
pad: 0
kernel_size: 1
It doesn’t look like I can crop it in the same way as the FCN-Alexnet, as the layers aren’t the same.
Can someone show me what needs to be trimmed on this net and explain it a little so I can figure it out for myself next time?
Thanks a LOT!
