Depending on the network camera, the phenomenon may or may not occur.
If you need information on the network camera where the phenomenon occurs, we can provide it.
Please share your device(Jetson platforms or x86 dGPU) and release version.
If you use Jetson platform, please check if the issue also happens in using nvoverlaysink:
num-extra-surfaces : Additional number of surfaces in addition to min decode surfaces given by the v4l2 driver
flags: readable, writable, changeable only in NULL or READY state
Unsigned Integer. Range: 0 - 24 Default: 1
disable-dpb : Set to disable DPB buffer for low latency
Boolean. Default: false
enable-full-frame : Whether or not the data is full framed
enable-max-performance: Set to enable max performance
