Network problems two nics one using usb c other using ethernet port Jetson AGX
Hi, I have one problem with the Jetson AGX using two nics one local and the other for the internet, one is using a USB-c to ethernet converter for internet connection, and the other using the native ethernet port for a local network. The problem is that when I reboot the jetson it lose connection until I connect and reconnect the USB C and one thing that worked is connect a USB device to the USB C flashing port
Some recommendations for the correction of this issue
It sounds more like a problem with the USB device perhaps requiring a power cycle to trigger a re-detection or re-initialization?
What does “lsusb” say about the device before rebooting, and after?
What does “dmesh” and the udev logs say about the device after rebooting?
Can you disable and re-enable the device with “ifconfig” or a similar tool?
Thanks, I will check these two options that you comment or have information about best practice to config two interfaces one using USB-C and other the local port
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
