Hi Everyone
Just to announce that I am developing a C library to manage the Jetson Nano GPIO, the novelty is in that is the only one that I am aware of that does NOT use the kernel tree (/sys/), therefore it does not need previous kernel configuration or anything like that, I use DMA to write directly into the CPU registers through mapping onto /dev/mem to get low latency and higher degree of control.
Anyways, I tested most pins with an oscilloscope and it works so far, looking for beta testers, maybe this is also useful for people trying to get a deep knowledge of the machine.
FUNTIONALITY:
JETSON NANO (TX1) family only, so far it does not support the Xaviers, etc. No hardware to test it
GPIO control of all the header pinout as input or output
PWM (hardware) control on header pins 32 & 33
Serial communications such as I2C, SPI and UART are NOT supported yet
No need of previous kernel configuration, the library will take care of that on runtime
Low latency is expected (it does not go through the kernel) direct writing to the registers (DMA)
IT IS A VERY ALPHA, INCOMPLETE VERSION AND ALL SORT OF BUGS ARE EXPECTED!
