New install wrong libc6 libraries + more and cannot update it?
I was able to install the jetson 6 software on the sd, boot the drive, login and then use sdk manager to update the os. However, some of the liobraries are out of sync or something. I cannot install or upgrade Ubuntu due to these errors.
example:
sudo dpkg -i code_1.87.1-1709684532_arm64.deb
Selecting previously unselected package code.
(Reading database … 175277 files and directories currently installed.)
Preparing to unpack code_1.87.1-1709684532_arm64.deb …
Unpacking code (1.87.1-1709684532) …
dpkg: dependency problems prevent configuration of code:
code depends on libc6 (>= 2.28); however:
Version of libc6:arm64 on system is 2.27-3ubuntu1.6.
code depends on libgssapi-krb5-2 (>= 1.17); however:
Version of libgssapi-krb5-2:arm64 on system is 1.16-2ubuntu0.4.
code depends on libxkbfile1 (>= 1:1.1.0); however:
Version of libxkbfile1:arm64 on system is 1:1.0.9-2.
dpkg: error processing package code (–install):
dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) …
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) …
Processing triggers for bamfdaemon (0.5.3+18.04.20180207.2-0ubuntu1) …
Rebuilding /usr/share/applications/bamf-2.index…
Processing triggers for mime-support (3.60ubuntu1) …
Processing triggers for shared-mime-info (1.9-2) …
Errors were encountered while processing:
code
exampplpe 2:
vscode-linux-deb.arm64.deb 100%[=======================================================>] 88.60M 1.87MB/s in 46s
2024-03-12 14:25:46 (1.93 MB/s) - ‘vscode-linux-deb.arm64.deb’ saved [92899934/92899934]
Reading package lists… Done
Building dependency tree
Reading state information… Done
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
code : Depends: libc6 (>= 2.28) but 2.27-3ubuntu1.6 is installed
Depends: libgssapi-krb5-2 (>= 1.17) but 1.16-2ubuntu0.4 is installed
Depends: libxkbfile1 (>= 1:1.1.0) but 1:1.0.9-2 is installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
and yes, I tried running the fix commands.
Please run the commands and check if the package is listed:
$ sudo apt update
$ apt list -a | grep libc
Jetpack 6.0DP(r36.2) has default rootfs in Ubuntu 22.04. Version of the packages matches with 22.04. So certain versions may be incompatible and cannot be installed.
there are a ton libcs listed
But for some reason the jetson 6 I downloaded installed ubuntu 18.04 and I was unable to perform a release upgrade. I since installed the sdk and I just tried the release upgrade again and it appears to be upgrading. I will update this post once completed by tomorrow.
Sorry for the late response.
Hi, no was not able to correct 18.04 direct install issues, so I followed steps to uninstall chromium and upgraded to Ubuntu 20.04, which solved my problem. I was able to install visual code, nano and other apps without issue.
