Hi
We have 3 workstations running under RedHat Enterprise 7.4, each of them having a few K6000 graphic boards.
The configuration is relatively complex since the workstations are used for visualization on a monitor of approx. 6700mm x 2300mm. Since RANDR did not adjust the screens correctly, we did it manually - I am posting the xorg.conf below.
Everything was working fine, until driver version 384.90 was released. Since then, the screen is black. If RANDR is enabled again, the screens show up, but in an incorrect sequence. Disabling RANDR as we used to do all the time, now gives a black screen (with all 3 workstations).
Our guess is that now RANDR must be used and without RANDR it does not work anymore. Is this correct? Can this be changed again or is there a way to fix this problem?
It worked ever since we installed and configured the system, but now there is now way we can use the system anymore.
Thanks in advance
David
xorg.conf:
nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings: version 375.26 (buildmeister@swio-display-x86-rhel47-01) Thu Dec 8 19:06:44 PST 2016
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
Option “Xinerama” “0”
EndSection
Section “Files”
FontPath “/usr/share/fonts/default/Type1”
EndSection
Section “InputDevice”
# generated from default
Identifier “Mouse0”
Driver “mouse”
Option “Protocol” “auto”
Option “Device” “/dev/input/mice”
Option “Emulate3Buttons” “no”
Option “ZAxisMapping” “4 5”
EndSection
Identifier “Keyboard0”
Driver “kbd”
EndSection
Section “Monitor”
# HorizSync source: edid, VertRefresh source: edid
Identifier “Monitor0”
VendorName “Unknown”
ModelName “LG Electronics W2442”
HorizSync 30.0 - 83.0
VertRefresh 56.0 - 75.0
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BoardName “Quadro K6000”
BusID “PCI:2:0:0”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
Option “Stereo” “3”
Option “nvidiaXineramaInfoOrder” “DFP-0”
Option “nvidiaXineramaInfo” “FALSE”
Option “metamodes” “GPU-0.DP-1: 1920x1080 +1920+1080, GPU-0.DVI-D-0: 1920x1080 +1920+0, GPU-0.DVI-I-1: 1920x1080 +0+0, GPU-0.DP-0: 1920x1080 +0+1080, GPU-1.DP-0: 1920x1080 +2386+1080, GPU-1.DP-1: 1920x1080 +4306+1080, GPU-1.DVI-D-0: 1920x1080 +4306+0, GPU-1.DVI-I-1: 1920x1080 +2386+0”
Option “SLI” “Off”
Option “MultiGPU” “Off”
Option “BaseMosaic” “1”
Alternative Konfiguration
Option “SLI” “On”
Option “SLIMosaic” “True”
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section “Extensions”
Option “RANDR” “Disable”
EndSection
