New plugin creation in TensorRT
In the plugin documentation here, adding a plugin layer to a network with plugin name set to pluginName and version set to pluginVersion, we need to do the following.
//Use the extern function getPluginRegistry to access the global TensorRT Plugin Registry
auto creator = getPluginRegistry()->getPluginCreator(pluginName, pluginVersion);
const PluginFieldCollection* pluginFC = creator->getFieldNames();
//populate the field parameters (say layerFields) for the plugin layer
PluginFieldCollection *pluginData = parseAndFillFields(pluginFC, layerFields);
//create the plugin object using the layerName and the plugin meta data
IPluginV2 *pluginObj = creator->createPlugin(layerName, pluginData);
//add the plugin to the TensorRT network using the network API
auto layer = network.addPluginV2(&inputs[0], int(inputs.size()), pluginObj);
… (build rest of the network and serialize engine) pluginObj->destroy()
 // Destroy the plugin object … (destroy network, engine, builder) …
 (free allocated pluginData)
When looked at the sample sampleUffPluginV2Ext, I didn’t see all these implementation.
I am quite confused, how UffPoolPluginV2 is added into the network during SampleUffPluginV2Ext's build process?
Hi @edit_or,
Did you check the below link
https://docs.nvidia.com/deeplearning/tensorrt/developer-guide/index.html#example4_add_custlay_int8
